Best Way to Remove Old Fuel
Since I worked out-of-town for most of the summer, my boating season was short to say the least. Now I have around 50 gallons of gas I bought back this spring left in the tank. It's real gas with no ethanol, but come next spring it'll be a full year old. Sta-Bil says its good for up to a year, but I don't want to take the chance.
I tried siphoning through the fuel line, no go.
I tried getting a plastic hose down the filler, but it gets stuck at the 90° entering the tank, no go.
Maybe trying a softer rubber hose, like surgical rubber might make it past the 90°, I don't know.
Any Ideas? Thanks.
Any Ideas? Thanks.
See entry #21 and 22. Remove the boats fuel line from the filter input side and use hose clamp to connect it to the drainage pump system.
http://www.offshoreonly.com/forums/g...se-them-3.html
Registered User
I recently had to do the same thing, bought a used boat which had old gas in it. I tried several different ways as you listed above. I ended up un hooking my main fuel supply at the fuel pump on the engine connected a 12v fuel pump to the line added a 7-8 ft hose on he outlet side of the pump & pumped it all out. I had about 75 gallons only took about 30 min.
This way ensures you get it all out where if you siphon you can't get it all out.
Is your boat already equipped with an elec. fuel pump???
Can you remove your fuel level sending unit? I had 80 gallons of i year old fuel in my Formula and I pumped it out through the sending hole with a transfer pump. Took me about 10 minutes.
