42 fountain questions
hello , my 45 excalibur got wrecked in hurricane sandy
Im looking at a 42 fountain lightning and I have 3 questions
1 - how fast will it be with 500hp's
2 - it only has a porta potty and I want to convert it to a flushing toilet with a pump out , is it doable/feaseable
3 - it doesnt have a generator , would it be difficult to add it ?
thanks in advance
thanks in advance
The best deal on a 42 is right here. Owner is crazy meticulous.
http://www.offshoreonly.com/classifi...o48186-en.html
2 - it only has a porta potty and I want to convert it to a flushing toilet with a port a potty , is it doable/feaseable
thanks in advance
thanks in advance
Adding a flush toilet and generator can be done. Depends on what you consider hard work.
thanks in advance
thanks in advance
yes with some minor glass work
no
An option for your 2nd question - They make a pump-out porta potty with electric flush now. It mounts right where your current potty is and has a hose that mounts to a thru-hull fitting for the pump-out. The holding tank holds 5.5 gallons of waste. They actually look pretty cool and it would be much easier than installing a true pump-out system. Just an option.
Porta Potti 465 MSD - Portable Marine Toilet
Designed to Make Dockside Pumpout a Breeze
This durable toilet is sanitary, odorless and leakproof. Plus, high-gloss finish is easy to clean!
• Electric pump quickly and easily flushes fresh water to clean bowl
• Removable seat and cover for easy cleaning
• Sealed valve keeps odor in holding tank
• Built-in deodorant storage (bottle included)
• Hold down kit secures toilet to deck
• Easy-to-read Level Indicator tells when its time to empty
• Capacities: Fresh Water: 4.0 gal: 15 L
Waste Tank: 5.5 gal: 21L
