If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 3 of 3
  1. #1
    Platinum Member Platinum Member Tinkerer's Avatar
    My Boats:
    2001 Daytona 26, 1992 SCARAB 34, 1989 25 Checkmate Convincer, 1977 Glastron Carlson CVX 18
    Join Date
    Jan 2002
    ALTO, MI
    Ot- Maximum Egt- Diesel
    I have a 6.5 turbo diesel and have done some work to increase HP. Installed a EGT guage and would like to know what the maximum safe temperature is.
    Hey even if it ain't broke it's still fun to tinker with it.
  2. #2
    Join Date
    Dec 2000
    Flemington, N.J. U.S.A
    It depends where you put the probe . It should be in the exhaust manifold for best results .Some companies put them after the turbo . If it's in the manifold it should max at 1250 degrees . After turbo is kind of not so acurate . Closer to the turbo the hotter in may be .The farther down the pipe the cooler it is . And it cools off quick farther away . If it is after turbo , I would say 1050-1150 max depending on how close to turbo it is .
  3. #3
    Registered boathead's Avatar
    My Boats:
    2000 Powerquest Avenger
    Join Date
    Feb 2001
    Big Rapids, MI
    Not sure about the 6.5 GM, but I am told that my Cummins will go to around 1300 degrees for SHORT(as in seconds) periods, and I would imagine that this temp would be lower for the new Duramax as it has a lot more aluminum in it. Aluminum melts around 1200 degrees in unalloyed form, iron at 2700 deg.
    I've run mine up to 1350 with no ill effects(so far). If you're doing upgrades, the EGT gauge is a MUST, and a boost gage is also a good idea. I have the SPA Technique 206 electronic gage which I can highly recommend, it has a faster response time than analog gages, and it combines boost AND EGT in one gage. I got mine from Diesel Injection Service(not the one in Grand Rapids, although they might handle them) S.P.A website
    I currently have the TST 270 HP cam plate(I have an old 12 valve Cummins- easier to upgrade than those newfangled 24 valvers), which changes the wastegate so I can run 30 psi boost, and also changes the fuel cam to give her more juice, but I have to be judicious in my use of the accelerator pedal! I also added a 4" catback exhaust, and removed the cat. converter and silencer ring in the turbo, and went to a bigger air filter(NAPA 2790, or was it 2970?), which helped immensely in reducing EGT and let it breathe easier.
    Good Luck,
Similar Threads
  1. maximum hp to a bravo 3
    By in forum Drives and Lower Units
    Last Post: 10-29-2007, 12:44 PM
  2. Maximum Rpms?
    By GK in forum Scarab
    Last Post: 07-11-2006, 10:56 AM
  3. Chevy 3500HD diesel vs Ford 350 diesel
    By Boomer35 in forum Trucks, Trailers and Transportation
    Last Post: 09-29-2005, 12:12 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
