Interior vinyl
Interior vinyl
Any good place to order interior material online? I need gray, silver and green in the carbon fiber material....
Any ballpark guess as to how many yards of material I would need for a 33 powerplay?
Thanks!
Thanks!
Registered User
I just had my 2 front seats redone, 4 back seats, & both inside interior pieces done used about 18 yards keep in mind my fronts seats are not bulsters they are aluminum racing seats so they ate up a lot of yardage. Got all my vinyl from a local material store called "Jo-ann Fabrics" they had white, grey, orange, red & black in stock. Go online & get a coupon for 50-85% off I had under $400 into material. I did a lot of research before buying, it comes from the same supplier as a lot of the big marine manufacturers.
You can also try www.yourautotrim.com they have decent prices and shipping and also have a wide variety of different brands. Marine stuff of course as well as auto house you name it. If you don't see something just call and most likely they'll have what you're looking for just not on their site.
As far as quanties it depends on how much of the different colors you plan on doing. as well as if you're running welt cord to break things up or just want to seam the ends where the material folds over.
If you're doing the whole thing, bolsters rear bench and sun deck or do you have a race hatch?
I would give an educated guess of 8 yards of your main color (figure most stuff is 54" wide ) which you'll have plenty of extra, then 4 yards of each supplemental color. Also with plenty of extra. If you need foam they have that too.
Some of their stuff has backing on it for mildew resistance ect ect.
Good luck
Good luck
Contact Jim Cowan at premier performance interiors (ppi).
They got What you need, That most retail stores don't have is
1. 1/4 Laminated vinyl. Laminated vinyl has foam glued to it this gives it a plush look. Not flat.
2. Is make sure it is antimycrobal (keeps the mold away)
3. Is uv resistance
Tell them Chris sent ya. 941 752-6271
3. Is uv resistance
