Gasp...  Bimini Top needed... >
Old 04-16-2013, 02:33 PM
RollWithIt's Avatar
You sure Greg? It is a Baja... lol
I think I would want to go ss frame. Not too worried about the weight on this boat. I definitely want something sturdy so I can do some runs with it still up.
RollWithIt is offline
Old 04-16-2013, 04:14 PM
Fast Singles Club
the deep's Avatar
Cool
I think you just don't want the sun shining on your beer .
the deep is offline
Old 04-17-2013, 07:55 AM
RollWithIt's Avatar
That's why I got a boat with a fridge in it...
Old 04-17-2013, 09:39 AM
Joe
tcwcar's Avatar
i have one i want sell, its in great shape, it was on a 2000, 31 cigarette Mystique, got all the hardware to mount it, don't know if it will fit yoor boat, but some of the mounting bar are ajustable...Pm me if intrested....Joe
tcwcar is offline
Old 04-17-2013, 10:02 AM
Forum Regulator
Sydwayz's Avatar
Received 1,195 Likes on 519 Posts
Jason, I'd look into having something built by the guys at XT-Innovations. The generic ones are usually the cheapest built and most likely to fail at mounting points and seams.
Having something custom fit is the best bet. Go as low as you can have it and walk under it comfortably. The lower it is, the better it will be for riding with it up. You want all SS tube mounting points and no straps to hold it up. This will prove a little more difficult to setup, but it will be more sturdy and last longer, especially since it will be tighter when erected--allowing less flapping from wind speed. Less flapping also equals less noise.
There are a group of guys here in VA that had them built by a couple local canvas guys who copied each others' designs and tweaks. The guys who have them run at 70mph with them up, with no problems. You also want it all mounting points secure with THROUGH-BOLTS, and not screws. Screws will pull loose on such a structure.
Sydwayz is offline
Old 04-17-2013, 10:17 AM
I have one for sale. SS tube. 88"-92" wide. You would need to get the correct hdwe. for your application. Had it mounted on my Scarab and it just did not fit right. Aqua in color with the cover.
$300 + shipping
Jeff
sbslinde is offline
Old 04-17-2013, 10:51 AM
RollWithIt's Avatar
I'm going to do some measurements on the boat next time I am at the marina. My buddy had a Formula 357 with a top that had full ss framing and was very secure. I like the thought of having it sit low for the lower wind profile. And as my boat basically tops out at 70, something that secure would be great!!
Old 08-17-2015, 09:58 PM
Anyone have pictures of the tubular SS type on a cig? I've only seen one once in the 90's, in miami there was a top gun that had one, i'd always see it when crossing the causeway. It had the genie from aladdin painted on the side... looked pretty nice from far. I probably wouldnt do it but sometimes when its so damn hot i do wonder...
blown is offline
Old 08-18-2015, 04:58 AM
Default a stock cover is not going to cut it
A run of the mill top will not work....
I have a 70 MPH top (that I use at 65+ 90% of the time I am boating) and it took some effort to make it work....
If your boat does 70 MPH. Do you ever run to a 20 MPH+ wind? You need a top that will handle 90 MPH+ wind speeds to have a top that will handle 70 MPH
Find a local to you shop that has experance making tops (it not likely that they will have experance making high speed tops). and have them make you one to the specs below (you can remove the price I paid in an effort to get a better deal)
7/8 stainless is not going to cut it, for that matter either is 1" stainless.... You can either use 1.125 stainless or do what I did and use 1" Stainless with 7/8" stainless inserted into the 1" before bending it (the large bows only, the short ones are single wall 1"). The prices are similar but I like the look of the 1" (the 1.125 gives it kinda of an industrial look) and it is much harder to find fittings for the 1.125"
Use Sunbrella fabric and your going to want to use 4 bows, the canvas will have to be TIGHT (If I am putting the top up alone I have to use a small ratchet strap to get the screws in).
Make it as low as practical and it is VERY important that you angle of the top (which is basically a wing) be neutral (or flat) to the water when the boat is going fast. (use a level on the floor if your lucky it is level when your going fast, if not note how much it is off by and adjust your tops angle accordingly). make sure that the leading edge is back at least 2 or 3 inches from the top of the windshield (it can funnel the deflected air from the shield and turn the top into a parachute). The top needs to be designed almost flat with only about 3" of rise in the inner two small bows (and you do not care about rain run off).
Of course use 4 stainless to hold the top front and back (they can be 7/8 but for the few extra $$ matching it with 1" looks better). Forget set screws, use Stainless 3/16 rivets in all of the fittings for a few trips and once you got it adjusted where you want it drill all the way through the fitting on the leading edge (the ones that take the full wind effect) and through bolt with 3/17 stainless machine screw. "Do not try to use the top at high speeds with only set screws".
Once it is on the boat and you have blasted around some the fabric is going to stretch I suggest that you use a short length of 1" spa hose in the bow pocket as a shim till the fabric has had a chance to fully stretch (on the boat for a couple of weeks and 3 hours or more of blasting). Then you will have to take it back to the builder to have the two small bows replaced (they will be about 1" short because of the stretched canvas). My top guy bent the longer replacement bows at the same time he made the top while the bender was still set up for my width Etc knowing that they would have to be replaced. Once you replace the inner bows the front and rear supports will need to be shortened about 1.5 inches. This will give you a chance to adjust the angle of the top of you got it wrong the first time by taking it from the front of the back (or 50-50)
FYI: the top on my boat is 76 wide and 84" long, the cost to have it built was $1100. The shop made it clear up front that part of the reason the price was so high because he knew that he would have to tweek on it and that he would end up replacing the bows Etc. The top up reduces the top speed 3 mph, the top stored in the boot in the up positon reduces speeds 1 MPH (lay the boot down on the motor cover and there is no speed loss)
OK: I am ready for the jokes about the guy with the top on his boat.......
boating4me is offline
Old 08-18-2015, 07:37 AM
RollWithIt's Avatar
Wow..sounds like a nice top. Definately what I am looking for. Still have not gotten one as other things have been more of a priority. If you saw my other thread in the prop section you can see the latest. I will definately keep the information you listed and use it as reference.
