Stain on vinyl
Stain on vinyl
I got a finger print on my new cf vinyl during the Miami Run in Feb. and I cannot get it out. I don't know what it is but i have done everything I know of and nothing seems to work. Any suggestions would be greatly appreciated.
acetone is scarey, you get about one wipe before it eats it. I have cleaned some nasty stained white vinyl this way and had good results...
use one of those sponges with the green scrubbey scotch bright stuff..
1. pour laquer thinner on a damp scrubber sponge and scrub
2 next use soft scrub with the scrubber sponge
3. rinse well and then wipe down with 303
Thanks guys. I have tried bleach white, soft scrub, magic eraser and simple green with no luck. I was told by a friend to use vinagar and water. I do have a sample of the vinyl I can try things on before I screw up the real thing.
If the magic eraser or Soft scub doesn't touch it I don't know what will...
Try WD-40 then wipe clean with a cloth soaked with dish soap and water on it or try Spray Nine and once again wipe clean with a damp cloth soaked with dish soap and water.
