Can my 2000 7.3 f350 tow a 40 skater?
Charter Member # 545
Will it tow it? Sure, but what kind of towing you talking, to the boat ramp and back, or to poker runs all over the US. Stopping it is far more important than towing it. EOH brakes are a must. I have a 2000 F350 Dually with a 7.3. Biggest boat I towed any distance was a 37 Outerlimits on a steel Myco, that had only surge brakes. Their was no way you could stop that rig in a panic stop situation. I towed 5 Fountains the largest was a 38 on a steel Myco with EOH brakes, the thing stopped as if it wasn't even behind the truck.
Whether you are legal, or not is another question. Personally having towed from MD. to Fl. a couple of times, If you are planning on towing any distance, you will be more comfortable in a bigger unit. You will have to add an auxiliary fuel tank, or you will be stopping every a lot for fuel towing that Skater, if you are going any distance.
The Trailer is MORE important then the truck. The Trailer Handles the weight of the boat, stops the boat, controls sway and stability. A larger truck should NOT act as training wheels for a inadequate trailer.
Yes, if your truck is in good condition it will tow your boat.
At least you have a stronger hitch then the local walmart special!
Is it a dually or a SRW? If it's dually, make sure the trailer is in perfect working order and you're good to go. I agree from past 7.3 experience, that if you're doing any heavy hauls even for short distances, an EGT gauge is a must. Keep in mind that the skater likely needs permits due to width, that makes you a DOT target. Make sure the whole rig is within GVRW for that truck. But from a safety standpoint, a dually long wheel base truck will tow that boat without issue.
I can't believe anyone is endorsing this.
You are following your wife to the Lake House; she is in her Mercedes C300; and your 8 year old daughter is in the backseat. The light ahead changes to yellow, and your wife stops due to someone turning left in front of her. You stomp on your brakes, and burst a brake line on the trailer. Your rig is not slowing, and you are now starting to slide as your truck is being pushed by that 15,000 lbs behind you.
Finish the story.
Finish the story.
Finish the story.
Finish the story.
You should have a larger capacity truck such as a freightliner sport chasis,F-650 or Kodiak.These all have the higher towing capacity and the big air brakes to match.I would not recommend anything that does not have dual rear wheels and electric brakes.
