I need a Lee intercooler or just the core ! BAD ! >
Old 07-28-2002, 11:51 PM
Default I need a Lee intercooler or just the core ! BAD !
The one I had that was plugged was finaly cleaned out and flowing good as new . The one I thought was good , turns out leaks like crazy ! Does anyone have one they want to sell ? Or where can I get the best deal on one ? THanks ,JOE
boot is offline
Old 07-28-2002, 11:54 PM
Oh , I need water cross overs too please !
boot is offline
Old 07-28-2002, 11:56 PM
Charter Member #232
Audiofn's Avatar
Think there are some water cross overs in the classifieds.
Jon
Put your best foot forward!
Audiofn is offline
Old 07-28-2002, 11:57 PM
Charter Member #232
Audiofn's Avatar
Oh ya make sure you put the restrictors in the intercoolers so that water does not flow through them untill you hit the higher RPM's. Biggus just racked his head against the wall untill Nickerson told him the problem. Running perfect ever since.
Jon
Audiofn is offline
Old 07-29-2002, 12:21 AM
THanks ,Jon . How exactly did he set it up do you know ? What parst did he use ?
boot is offline
Old 07-29-2002, 08:10 AM
Charter Member #232
Audiofn's Avatar
I am not 100% sure were they go. As I understand just from talking to him they attached to the front of the intercooler. In line with the line that feeds the intercooler. Once the preasure hits a certain point the valve opens up and lets the cooler do its thing. I guess that they problem was that when the cooler was seeing water go through it at IDLE it would turn the fuel into Droplets that puddle in the bottom of the intake and run to the rear cylinders and foul your plugs.
JOn
Audiofn is offline
Old 07-29-2002, 12:49 PM
Jon, What I thought about doing was adding another set of water pickups to the transom to force feed just the coolers . That way you only get flow at speed ,not when sitting .
I have seen a few this way .
Can Anybody help me find a cooler ??
boot is offline
Old 07-29-2002, 12:52 PM
Charter Member #232
Audiofn's Avatar
That should work ok. I am not sure if Biggus has a large water pump or not that feeds his. So far his has been real good since he fixed that problem.
Jon
Audiofn is offline
Old 07-30-2002, 11:52 AM
Somebody HELP ! I need an intercooler . Where can I get a good deal on a "Lee" . And a water cross over . Thanks
boot is offline
Old 07-30-2002, 11:56 PM
I HAVE THREE LEE'S, WHAT ARE THEY WORTH? I WILL HAVE THEM IN A WEEK. CAN YOU WAIT OR DO YOU NEED RIGHT AWAY?
SlickNick is offline
Quick Reply: I need a Lee intercooler or just the core ! BAD !
