REX Marine Rigid Tube Drive Shower
http://www.rexmar.com/page142.html - pictured in the bottom. Does anyone have the template for this?
1 Post
fixx
rex marine has been at this the longest and their website still sucks
Get the simrek no drill, woks greatand bolts right on.
1 Post
the pick up..once you get the bigger hole drilled you put the pick up in the hole and drill the smaller hole with the allen cap bolt and lock nut...the upper you remove one of the upper cap bolts and install the spacer and put the bolt through the shower head and spacer and torque it to 20 ft lbs..once installed make sure the prop clears the water pick up..if it dont your going to have to trim a little off but it should clear..also measure the one you got,,they are all welded in differant spots so the 1/2 '' x 1/2'' may have to be altered.
