Poker Run Format - should it be changed?
#241
I see. So all that open water on the other side, and.... Further comment withheld to avoid pissing many off
#243
Yes there was a lot of open water. They prolly saw Phantom idling over and shot that gap to? Lots of boats runnin around and guys wanting to be first to the stop. It's gonna happen. If u don't like it stay home.
#244
"The canard allows the driver to more easily “fly” the boat, pushing the rear of the canard down to create lift and raise the nose of the boat, or raising it to lower the nose of the boat if it gets too high and is in danger of “blowing over”. The driver will also manipulate the canard in the turns or when rough water and windy conditions persist."
#245
OK I guess I'll be the first one to ask. In order to improve the safety of these events do we need to get the " JackApples" who are running to close to other boats at way to high of speeds under control? The bigger question is if so How? Just asking.....are the less than 100mph boats causing this much issue?
#247
If you don't like it stay home.
Sign this mouth breather up for the next safety committee .
#248
Poker Runs have been very lucky to not have any accidents involving spectator boats (knock on wood). From the looks of these videos its only a matter of time before that happens and then the stuff will really hit the fan. So far its been participants in the poker run getting hurt or killed, which is bad enough. If a spectator or person on a open lake gets killed they will have a open and closed case. There will be no question who is at fault.
The Poker Run event planners must make changes before it gets worse. (not sure knocking on wood is a good solution)
MP
MP
#249
I have bought this thread back after reading it, many good points have been made.
A decision was made to lock this thread since another thread has been started about the same subject.
Please be respectful of the family and family of Jeff Asbell & Brad Smith.
You are judged by the company you keep!
