What to do
#33
Here's one for you. Just like a Baja or Donzi. Very similar. 1994 Infinity, 265. Cuddy, Porta P. 454 Merc Mag, Bravo 1. Silent choice, Trim tabs. etc. Tandem trl. (needs fenders) New starter, Water and circ, pump. Nothing to do just wax, put your graphics on it (all white),. and gas. Now the good part. it's only $8500.
#34
Whatever you buy, make sure you have the hull checked out for moisture / rot. There are a lot of boats out there that may look pretty nice on the surface, and may even run nice, but if they were left outside in the elements, even on a trailer, there is a chance that there could be some rot hiding in the stringers and/or transom that could turn into an expensive PITA. There were a LOT of boats built, especially in the 90's, where corners were cut on the construction and surfaces were not sealed properly when screws were run into fiberglass-encapsulated wood. I have seen too many horror stories about inexperienced boat shoppers getting stung - and sometimes the seller is honest but does not know himself that he has a rotten boat.
If you can find a boat that was trailered and stored inside its whole life, you may have some peace of mind. But I have seen too many boats that were owned by idiots who stored them in a gravel lot with a leaky or non-existent cover, left the plug in, and then forgot about them all winter while they filled up with water and rotted away. Be careful!
#35
