What to clean an Aluminum Trailer with?
Try using Eagle One NEVER-DULL wadding polish first. If the trailer is oxidized (white) and polish alone is not working use a fine scotch bright pad with the never dull wadding on the back side of the fine scotch bright pad.The never dull on the back side if scotch bright is to keep it moist with the polishing compound. Rub one direction lengthwise then wipe clean with cotton rag or towel.
You have plenty of time before next season. The boats done and junior is walking. Take him to the shop with you, hand him a green scrubby and he can get all the hard to reach spots. A weekend, twelve pack, night at the farmington, breakfast at farmington and your done. If its snowing and you need a ride on a sled I will make some calls.
Member #154
Good luck with the project, it'll probably take some elbow grease and time.
Pretty sure this will work well....
http://www.biokleen.com/aluminum-cleaner
It sounds complicated and time consuming, but it was not.... Very easy, took an 1.5 hrs the first time, .5 hrs the time the second round. (It was only a 22 ft trailer)
Geronimo36
While down in Key West I met the owner of Myco Trailers while hanging out at the Chief booth. He was telling me about some kind of liquid they spray on the trailers and it makes them like new... Can't remember the name...it was a LONG week!
