When an XR drive is not enough, is there any other options other than #6 drives?
I would hope a pair of 525's with bulletproof outdrives would get me north of 80 in a 33-37 fountain or similar light hull. I'm thinking any boat that could keep up most likely will blast past me and a couple of MPH is not going to make any difference.
I know with my budget, 3 digit speeds are not an option or within my ability to be safe. I would get hurt in a Cat, I am pretty fearless which is not necessarily a good thing.
SCX is the way to go!
Yes I may have lost 2-3mph on the top end but I will trade that all day long for the reliability! I popped 3 Xr drives within 2 years of bumping up my motors (less than 80hrs of run time). Have loved my SCX drives for 3+ years since then!
The loss of mph going from IMCO SC to SCX is due to a wider gear case housing to contain bigger gears and bearings and a slightly longer strut , which could be trimmed if needed . The trade off in a couple of mph is worth the increased reliability .
Registered User
Going from and Bravo 1/XR to an Arneson, it will be roughly 50K for the pair with all parts needed to install the drives which does not include #6 style props at about 10K. The major components included in the kit are: drive, extension box, Trans, steering rams, trim rams, helm unit, bell housing and mount. I believe I covered most of it.
Going form a Bravo 1/XR to SCX it will be roughly 30-35K for the pair which does not include #6 props at about 10K. The major components included for that cost are: drive, reservoir and helmet. If you have a Bravo 1 gimbal housing I would suggest upgrading the whole thing with what IMCO offers. If memory serves me right it is around 6K each. If you have an XR you can get away with just the gimbal ring at around 1200 each. And you still do not get extension boxes in all of the cost.
So, if you replace part for part the Arneson is the more logical way to go. I also think that it is up to the individual to figure out what best suits them and their situation. But I will say this from what I have read you are more likely to gain speed with the Arneson. So in my opinion money well spent. Oh yeah, Rik has been awesome to work with.
Note: These are rough figures.
I had SC lowers already so for me the SCX conversion was a no brainer. I had to buy uppers, helmets, gimble rings, and tie rod. The SC lowers use the Bravo props so no need to buy new props. Total cost for me was around 25K. A full SCX drive will bring the bill to roughly 35K for everyhing.
The Arneson package is Awesome and I did look at it but it was cost prohibitive for me. The package was roughly 50k, props would be 8-10k, and I had to do some fiberglass work on my transom notch to fit them (adds dollars and set up ???).
A pair of used wet #6's is by far the best drive for the money out there right now. I've seen a couple sets with gimbles for under $20k. Used trannys $1500 for a pair and used props (4 blade) $2K for a pair. Now you're at $23K give or take and have to get the glass work done. I'm sure for under $10K you can get the glass work done and everything installed. So, for under $35k you have #6's on your boat.
