can you weld headers with an aluminzed coating?
It has been my experence that the steel will melt before the ceramic in the coating. The best thing to do is go to a pool supply company and buy a gallon of muratic acid. Break thru the surface coat with your 80 grit sanding wheel, then dip the part to be welded in the acid for a few minutes. This will pull the coating out of the pores . Rinse the part off with water, blow dry with air .. and it will weld just as clean as new metal.
This also works well on getting the cad plate off of grade 8 bolts .
Be careful of the fumes ... wear a resperator
Racer
Racer
Not to jump in anybodys bowl of fruit loops of how to do this repair but this is what I do we build custom headers end exhaust so I have I bit of a clue of what im doing some days keep your comments to your self dave haha.
Grind were you are going to repair clean as good you can weather its ceramic or powder or paint it needs to be as clean as possible and if at all possible tig weld not mig you will get a nicer more controlled weld but if you mig remember thin tube it will burn away easy.
Remember the cleaner you get it and the better your fitups are the easyer the job will be have fun good luck.
Also the acid is a good idea we also do that sometimes if we are repairing old dirty stuff make it clean is the key and if you mig don't use flux core wire.
So they are ceramic coated..?? Not alumnized tube..? I'd be positively sure it got ground to base metal before welding. Regardless of the process.
Practice that tig, if I have a choice ill tig it every time.
Cardinal rule with welding, cleanliness is next to godliness.
Cant really speak to your folical delema .. and I would imagine if you could stand the pain of inhaling hydrocloric acid fumes long enough .. then yes I would think it could kill you . But then you'd really have to be pretty brain dead to just stand there ...
Not cordinated enough to TIG weld ... maybe you been hittin the pool store already ..
http://youtu.be/UNAAhwieNhU
This guy makes really good videos. If you get some time check it out.
DO NOT USE ANYTHING CHLORINATED TO CLEAN WITH!!!!!!
Everyone who welds any thing should read this article. http://www.brewracingframes.com/id75.htm
This tubing you are welding is ceramic powder coated(Jet Hot) mild steel? Correct?
You said you couldn't get the aluminum to puddle. Aluminum is welded on a/c high frequency. Mild steel is welded on electrode negative d/c. That may be part of your problem. What wire, size wire, tungsten type, tungsten size, and amperage are you running?
