whats out there for big hp n/a engines? 632ci and bigger
#41
I had 598" kinsler injected brodix 351 Oval port cnc with a healthy cam would make around 900hp 6500 rpm. 10.0 to 1CR
598" Head hunters 383mc same cam and dry sump made 960hp 6700rpm over 800+lbs at 4000rpm little hard to plane off with full load of fuel. Needed weight in the nose
One advantage to blower you could run stainless marine exhaust less maintenance no Leakey headers.
#43
the boat is going to run sever days a week, a little over 2 hours a day. so diesel make sense. no matter what gas engine set up i run it will be a lot more thirsty than a diesel and need 5 times the maint. i would like to have a pair of 8.3 cummins built with a few mods and mechanical injection.
i was thinking about just running crash boxes. in front of a pair of arnesons.
will a good set of crash boxes hold up behind a 8.3 diesel in a heavy boat? thx, rm
#44
The crash box or BAM other 1:1 transmissions with no drop down cannot run in reverse under full power ,make sure you buy a set surface drives that have a LH and RH rotation ,or you will run in the same problems I have ...
#47
It can be either a under drive or an overdrive in ratio ,or even 1:1 ,drop down boxes are used when there ,s a straith output Arneson ASD 8 for example ,you,ll need a drop down to raise the engine ,because the oil pan will have to go through the bottem of the boat ,most drop down trannies are 5 inch drop ,but remember when you have a big gasoline engine with 5500+ rpm and 700 or more horsepower ,there is no gearbox with drop down to be found in that range ... I ran into that problem and spoke with Rik at Arneson ,he assumed I would use a chainbox and a gearbox on the transom for LH and RH rotation ,my ASD8 would bolt up strait to those boxes nso I coan use either crash boxes or BAM /cyborg
#48
motor's built in Miami Cobra power 598 ci. 725 carb to 800 efi I would go efi .
also there's a nice diesel offshore boat for sale in the classified's here on OSO it has FPT 560's and run's 90+mph . Fpt make's the block's for cummins from what i have read.
link to boat
http://www.offshoreonly.com/classifi...o55791-en.html
link to motor
http://www.offshoreonly.com/classifi...o54063-en.html
link to boat
link to motor
#49
[QUOTE=mikebrls;4096149]motor's built in Miami Cobra power 598 ci. 725 carb to 800 efi I would go efi .
link to boat
link to motor
http://www.offshoreonly.com/classifi...o54063-en.html[/Qi
i saw that black boat, there was a build thread years go about a guy building an alum offshore boat, i dont think it ever really it got sorted out, and i dont think they built anymore...
the more i think about it i need to go diesel with arnesons or 4stroke outboards... conventional i/o with a gas motor will be too much fuel and maintenance
link to boat
link to motor
#50
link to boat
link to motor
link to boat
link to motor
he builds a ton of engines. his crew is always in build mode, he has a ton of motors built and ready to go at any given time. and he does build a good motor and gives a guarantee, the guarantee makes a big difference, but being in so. america... wouldnt help me a bit. lol but still 34,999 vs 16k for a shafiroff engine. im ok with a single 4bbl but you can buy a f.a.s.t efi system for around 2500, which is only 1500 more than a 1000 dollar dominator...
