If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 5 of 5 FirstFirst ... 345
Results 41 to 43 of 43
  1. #41
    Registered Ratchet's Avatar
    My Boats:
    94 31 Scarab Thunder
    Join Date
    Sep 2001
    Lake St. Clair
    Cool As the owner
    I really enjoyed reading all of the postings up here..............
    As the owner of this boat, I'm pretty happy with the performance. I was a little leary of what the small blocks would do in that boat since I never saw any done like that, but I figured what the heck, it'll be something to talk about ! You should see the looks I get when I open the hatch cause noone believes me - lol
    Anyways, there were a lot of comments listed, so let me give you some of the specs:
    94 scarab thunder - loaded, every option, and nothing stripped out of it. Everything works. It has 1.5 Bravo 1's with Latham steering & a 1.5 ratio. I have seen weight listings anywhere from 7500-8500 lbs (dry wt) in the scarab catalogs, so I would estimate mine would be about 7200 plus fuel (just a guess). The gas tank is 150 gallons (I know it can take at least 120 gals :-) So full of gas I would anticipate that the boat is somewhere in the low 8000 lb range.
    355 2 bolt mains home grown chevys
    6 inch Lunati Rods (the cheapest street race rods) & pistons
    9.5:1 (calculated) compression ratio
    Cam - crower solid roller 250/252 @ .050 - .584 / .596 after lash with the 1.6 rockers - valves lashed at .024 / .026 hot, once a year !
    Springs 210 on the seat 550 open plus the rev kits.
    Heads - canfield 200 cc - out of the box from comp products (but we just touched the bowls during the rebuild)
    Intake - Vic JR - untouched
    Carb - modified (proform carb body) 750 Holley Double-pumper
    MSD Ignition - timing set to 36 degrees BTDC.
    Stainless marine exhaust
    This a naturally aspirated set of motors, no blowers / turbos, etc.
    I have never had the engines dynoed, but ran them for 385 hours before the rebuild without a failure. I used to spin them at 6000 rpms in my old boat also. The only thing I replaced on the engines was a starter & a circ pump. So if they last that long in this, I'll be happy. I anticipate the HP to be around the 440 hp range..but you never know till its on the dyno.
    To date, the top speed is 70.7 mph - I'm still experimenting with props. Anyone have a lh 23 mirage plus I can try ?
    I think I can most likey squeeze 72 or so out of it once I tweak it.
    Oh yes, these are GPS numbers, but the nordskog speedo is actually within a mile an hour or so (when the tube isn't bent).
    Let's just say, for what it is, it holds it's own, especially in rough water, so I'm happy. The only thing I notice is it sits a little more level in the water (since I took some weight out of the back) then my other friends 31s. That seems to work out well. I didn't need much tab at the poker run I went to a few weeks ago here in Lk St Clair.
    Anyways - just wanted to respond..............
    By the way, do they think that by putting signs on Gull Island (I saw that on the news) that they're gonna stop the parties ???? - What's next ? signs in muscamoot, strawberry island ? Either way, I still plan on attending the jobbie nooner next year - someplace !
  2. #42
    Chuck, your friend with the 27' Blue Striped Fountain...
    Was he at the Coastal Marine Poker Run this last weekend?
  3. #43
    dude 70 in 30' is fast enough
Similar Threads
  1. Guess what kind of boat this is...
    By dankerst in forum General Boating Discussion
    Last Post: 11-07-2006, 01:22 PM
  2. Guess the boat!!
    By TeamSaris in forum General Boating Discussion
    Last Post: 10-17-2006, 07:32 PM
  3. who can guess this boat?
    By Surgin' General in forum General Boating Discussion
    Last Post: 03-17-2004, 11:05 AM
  4. The Sub is up and almost running - guess how fast and win!
    By G-Force in forum General Boating Discussion
    Last Post: 09-09-2003, 07:32 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
