Long trip, Bad Bearing...
#46
Youd be amazed at what difference tongue weight makes, My axles are a bit too far forward and my tongue weight was light and the trailer was all over the road... I experimented all summer and the further I put the boat forward the better the towing is.
I even modified my rear bunks so I could pull the boat up without tearing the pickups off. I have a mark on my winch cable so I know when its up far enough.
#47
Compare and contrast these setups with everything pictured so far:
[ATTACH=CONFIG]521386[/ATTACH]
[ATTACH=CONFIG]521387[/ATTACH]
[ATTACH=CONFIG]521388[/ATTACH]
[ATTACH=CONFIG]521389[/ATTACH]
[ATTACH=CONFIG]521390[/ATTACH]
[ATTACH=CONFIG]521391[/ATTACH]
Look at the step distances from axle centerlines to get quick reference of CoG & placement.
#48
I'm def moving it up. Like I said just worried about front support. I hope adding to the current I beams will be enough. I'd really like to have a steal trailer after seeing the way those look.
#49
Pics 2 & 3 are Aluminum.
My advice would be to contact Manning up in Michigan and get a better trailer. I hate to say that, but I won't lie to you.
Buy aluminum.
You can get the same amount of support out of an aluminum C-channel welded trailer built by Manning (or Myco) that you can get out of steel.
Why 1: You could use the weight savings over steel.
Why 2: Steel limits your resale market. Only ~1/3 of the continent's buyers are eager to buy your boat on a steel trailer. With aluminum, anyone can buy it.
You can sell that trailer and recoup some of your costs on the new trailer. It's boat trailer buying season!
I GUARANTEE you will be better off in the long run. I've been there. I rebuilt my POS Rocket trailer years ago: bunks, breaks, axles, bearings, tires, lights, wiring. The only thing that was original when I sold it was the I-beams practically; and it was still a marginal setup. I'd have been miles ahead just starting from scratch on a well engineered and well built trailer.
#50
Buy aluminum.
Buy aluminum.
