Lexan / Plastic Subwoofer Boxes
Have had excellent results skim coating the mdf with fiberglass reinforced body filler. You must follow up with a coating after. Makes a nice smooth surface for painting too if you're not planning on using upholstery.
Ok guys, so we looked into the options, and we found in our situation it would still be best for us to use MDF. I looked for the Advantek and coosa, but neither was very readily available, and truthfully, I do not mind replacing it every few years. So, I now have the next question. What type of resin to use. West systems epoxy or west marine polyester resin. Is hardener necessary? Also, would it be beneficial to put a layer of fiberglass on it, or would that just be a waste?
Thanks for all the input.
