Best amp for running (6) JL Audio M880's??????? >
Old 04-15-2014, 11:25 AM
Originally Posted by ChargeIt
You might check out the Sinister SD6 from WetSounds 6x185 @ 4 ohm - https://wetsounds.com/pages/products/SD6_spec.html
They put out a durable, marinized, high power product. The price is up there but I am just making assumptions that is not the end all for this system.
I would also use the Wet Sounds SD6 if one amp is your goal, one JL M600/6 does not have enough power for 6 M880's, but you could use two of them bridged. Always better to have more power than you need and adjust the gains as needed.
I have 4 M880s in my boat and they are running off the bridged channels of the M600/6's the other 4 channels unbridged are powering the 4 7.7's,
pstorti is offline
Old 04-15-2014, 12:51 PM
BigSilverCat's Avatar
He listed that he only wanted one amp, but I'm with you, two JLm600/6 bridged would not be much more money then the focal amp that was listed but would be more power and sealed better for the saltwater environment.
BigSilverCat is offline
Old 04-15-2014, 01:19 PM
How about that SD6 from wet sounds?
302Sport is offline
Old 04-15-2014, 01:43 PM
http://www.arcaudio.com/p/xdi-1200-6?pp=24
Funnone is offline
Old 04-15-2014, 01:47 PM
All I know is that the boats I have heard with Wet Sounds systems are LOUD and Clear, granted they have more power and bigger speakers than mine but that amp has some power, much more than anything JL makes and unless you only boat in fresh water its a mistake to use something not designed and built for the marine environment. IMO
This is for the Nortech or the Intrepid? No subs or tower speakers??
pstorti is offline
Old 04-15-2014, 02:03 PM
Nortech, want to keep it simple but loud, don't want 16 speakers everywhere.......
302Sport is offline
Old 04-15-2014, 02:08 PM
8 M880's properly powered are going to be deafening in that small area!
pstorti is offline
Old 04-15-2014, 02:24 PM
Can only fit 6.......
302Sport is offline
Old 04-15-2014, 02:26 PM
sorry mistype still deafening!
pstorti is offline
Old 04-15-2014, 03:47 PM
[ATTACH=CONFIG]522063[/ATTACH]
you can put as many as you want, just grab a sawzall. These holes are for 8 - 15" subs
Attached Thumbnails Best amp for running (6) JL Audio M880's???????-subs.jpg
