Sea trial 2005 Fountain 35 - what should I look for?
OK, I'm in the process of buying a 2005 Fountain 35 Lightning w 525s. It has 160 hours relatively light use. Boat looks to be in excellent condition. I've read a lot about the header leaking issues so short of pressure testing them what can I look for during the sea trial which might indicate problems. Short of the obvious (rough running, hard shifting, gauge readings, etc) are there other tell tail signs of problems to look for relating to the engine & drives. Any and all advice is appreciated.
get them scanned. takes only minutes. Headers are not cheap. Keep that in mind as those seem to be an item most owners of 525's switch out eventually. Might be worth it to have a certified merc mechanic go over the motors drives gauges and have a surveyor look at the hull.
Look for? See if you can find that other three feet of boat in that 32 footer! lol All kidding aside, sounds like a nice boat if the price is right. Just add in the price of a new set of headers when you figure the price. At 9 (really 10) years old, it should be about time.
Stringers should not be an issues on that vintage. Check the transom at the bottom of the inner transom plate, look for water stains cause by rotting wood. The sealing of the hole cut for the drive leaves a lot to be desired. You can also shine a light from the top side and look at the transom in between the plates under the drive shaft.
Some of these boats get wet in the cabin too, the carpet should notify you of water issues in the cabin. Jump on the floor a little and see how it feels.
Header can be an issue with 525s, I read a lot and know someone that had issues. However I also know quite a few with more hours than that....no issues.
Scan will show hours by RPM, its a must. If the dealer is willing I would also have them drain drive oil and remove rear caps from drives to inspect the XR gears. 200-250 is about the life of the gears under normal use, however abuse will shorten that life span. You will be looking for metal chunks (not shavings) in the oil, and chipped or pitted gears in the drive.
Besides that just prepared to go fast in a stable ride, and take a beating from old school boats without molded platforms picking on the LOA measurement. Seems to really hurt those guys deep how fast you will be able to go in rough water, so you will pay for it with childish jabs
Check for busted stringers in the v berth, being a fountain I'm sure they've been beat up pretty good from the top.
