Convincor or Aggressor
A friend of a friend owned that boat (if it is the one I think it is.) At that time it had a wet transom. Was having issues keeping the trim tabs on the boat. I think they were bennet tabs and weren't thru bolted, just screwed into the wet transom.... I would definitely have a survey done.
I think I have heard enough to not pursue the Sunsation, plus I have some additional pictures that show that it really hasn't been taken care of that well. I think I'm going to take a closer look at the convincor. What are the opinions on Checkmates build quality? Anything in particular to look at? Also, I'll get a survey regardless of which direction I end up going.
I agree 100% with the survey, I'm not disagreeing with low_psi, and I don't know the history of the boat posted, but I know a dealer in Harrison TWP, MI has a 2000 Aggressor listed with Bennett Tabs and is advertised with a new transom replacement having just been done. Gel/graphics look very similar, they may be twin sisters. Fraternal twins, though, as the windscreens are different colors.
Checkmates's mold work is second to none. The entire hull and topdeck are fully end grain balsa cored. Floors and stringers would be a concern...(like in any other boat). The Checkmate is a solid riding boat and the Convincor hull design has proven itself through the years and even raced successfully. The other area of concern for the Checkmate would be wiring behind the dash. Unless it's been redone or upgraded you may find a rats nest of wiring! The Convincor is a big deep boat and will keep your family feeling safe on the water...good sized cabin too!
Yeah, it's listed on a couple sites, and at Hideaway in Harrison TWP.
Based on your criteria, the Check hands down and that's from another 24 7 guy. Another post hit it on the head. The gel and glass work on a Check is as good as any in the industry. Don't buy anything without a thorough sea trial. Good luck
