Smoked a bearing on the trailer. Boat is stranded in Michigan
Chris,
You sound as anal as me about bearing service. I have towed over 15,000 miles and only one bearing problem. Going to the ramp at State Dock at Cumberland is a 4 mile slight downhill. The brakes can get real hot. Backed the trailer in and the pads delaminated from the sudden temp change. I always grease up before backing in to help cool the bearings. Lately I have been carrying several jugs of water to cool the brakes and bearings down before greasing so as not to suck water in when they hit the ramp.
You might be on to somthing. I keep thinking somthing else failed leading to the bearing failure. Why else would the spidle have survived? If a brake shoe broke first, that may have jammed in the hub cracking it and stressing the bearing to the point where it fractured. Even the cylinder shaped bearings that were recovered were undamaged.
Yup, that's it. My trailer jammed the brake shoe material between the drum and shoe and locked the wheel up. Did not jam up until the trailer was backed. Did you back up when you put it up for the night? Had to take it apart and clean the obstruction out, vise grip the line and fix it in the parking lot where I bought the new pads. Just let those baby’s cool before quenching them. Put some recycled Mountain Dew or coffee on them if ya hafta! Most show failures are due to quenching and I suspect that the bearings don’t like it either.
Tim T.
Tim T.
Chris,
If you need any help, let me know. I will be in South Haven this weekend. I could pull it back to Alsip, IL if you want. My boat stays up there. I'm planning to go to the race in Grand Haven. I've read so much good stuff about LOTO and the C.O.P.S. run that I need a race fix.
Roger
Roger
Quite, thanx for the offer but the boat keys are here with me. We noticed a large cruiser at the north side municipal marina that is also named Quite Storm. You have two boats? I think I saw your boat parked near the road leading to the public ramp. Is your place one of the condos along the river with garage underneath? We have talked that one of those would make a nice investment. I may head up to the race for one day as well since I'm going that way. I hope the water is as nice as it was last weekend. Calm and very warm.
Chris,
I can only tolerate the aggravation of one boat. That was my boat in the lot. We have unit #12. Stop by anytime. I was in Seattle last weekend. Thats why the lake was calm. Since I'm back, it may be rough. My luck. Hope to see you.
Sorry to hear about your problems Chris.
There will be several of us from Northpoint going to Grandhaven this weekend if you are interested in meeting us.
Good luck with the surgery. If you need some help with the winterization thing or towing the boat around this fall let me know.
Steve
Steve
cbeastwood
6
05-29-2007 09:33 PM
RUSSSR1
06-30-2003 08:56 AM
