Ford guys..electrical help//
95 ford exploder... Windshied wipers started acting up, would not turn on, leave switch on going down the road and poof they turned on but would not turn off. now they wont turn on at all.. Im guessing multifuction switch?? any other ideas? Or how to bypass everything and just wire the motor up on and off?? what color wires??
Thanks.
Thanks.
on mine i think its the delay that acts up and causes that. If i switch from the delay to full on and back a couple times its fine.
08 OPA High Points Champion
Had a problem on my 98 f150. It was a ground problem where the switch assembly screwed to the steering column. But mine didn't work an always turned off. That's all I have for you. Good luck. Artie
Ford uses some fukery with the GEM module to control the delay cycle. Could be the switch, GEM module, or the wiper motor. There is really no quick diag to pinpoint the problem. If you just want to bootleg up a switch and make the motor work at will, throw power on the white wire of the wiper motor connector. That should get you low. If you throw power to the DB/O (Dark blue with orange tracer maybe? I hate Ford color coding) instead of the white that should give you high speed. Rig up a three way switch and you would be a sloppy mechanic baller. At any rate, here is the diagram, do with it as you wish.
[ATTACH=CONFIG]529290[/ATTACH]
i think you should pull it all and install a carbon dash with all new switches. . . . race seats . . . . paint truck white . . . . black stripe and custom Salvador Daly installed pleating . . . . . baller hauler mini style . . . . or put a hitch on the Caddy
1 Post
check the ground at the wiper motor,,common problem..loosen the wiper motor screws and cleen and reinstall them..if that dont work then its the delay module like mentioned..
Thanks.
Thanks.
Hope this helps, Good Luck!
Donzi Matt....do you have the diagram of the control side (MF switch)?
