Oil drain hose
Yes I just need to know if the hoses are going to work on my boat first lol
I tried a thin hose down dipstick tube. I sucked oil so slow ended up burning up 2 pumps before I gave up. Get a hose that fits over the outside of dipstick. I keep a hose clamp and a nut runner in my oil change pump box. Tighten the hose clamp on the hose after it is slipped over tube. It sucks way way better than the thin hose.
1st question will be are you planning to install these while the motors are in the boat? The bilge pumps are right below the drains and that with the abundance of working space doesn't exactly make this a walk in the park. It is reachable though if you are a small person. I can wiggle down under the pumps and lay down on the floor and reach my drains, but not something you wanna do for each oil change. If you do/can install hoses, make them long enough so you can route them up front and just use a small pump connected the hose to pump the oil out, then cap the hose when done and attach the hose to a bracket to prevent it from flopping around. A pump connected to a drain hose will suck the oil out in a matter of few seconds.
