A Little Carb vs EFI info
#31
Can think of a lot of carbed cars that had tuned length systems like all of them some were just better thought out than others like my cross ram 413 wedge dodge
#32
I'm sure carbs are the cats azz... for people who like to play with them, but if you want to go boating with the little free time you have how could you not love efi.i have plenty of old temperamental farm vehicles to fill my need of tinkering on chit so it will start and run when needed.
#33
Here is the story I wanted to post but could not from web as I had to find my magazine first to be able to pull it up off the web to post the link to it. Read it please as back in 2010 I thought it was a good tech story. So here it is, the web version. The other stories all come to my email, it gets very cluttered everyday. Link below and read it if you like. I went thru a little work & time to find it.
http://www.hotrod.com/how-to/engine/...6-l-mod-motor/
#34
Then I went further than the factory fuel lines could handle. Put my dual quads on took less time to tune them a couple jet changes and a couple air bleed changes and was all done. Have been giving thought about a coil pack set up and ditching the dizz would improve it more than anything at this point.
#35
^^^ auto ECMs & fuel injection yes, marine ECM's & injection no. I am in favor of fuel injected in boats but OEM marine fuel injection in the 1990's really nothing special nor ran any better than carb marine engines back then. Also there was no fuel savings running an EFI marine engine in the 1990's from the OEM's compared to carb engines. OEM Marine fuel injection currently is finally catching up with the auto side but still has some distance and a long shoot away for tuning / remapping the ecms compared to auto's. I will say at least marine fuel injected engines are not 15 years behind the times compared to auto's like they use to be, they have closed the gap but not completely.
About 5 to 10 years from now it will be huge common known issues publically about marine catalyst engine problems from the ones that have been currently produced. 3 way catalyst systems in the marine environment has no longevity.
#36
Have worked on several high milage cars with factory SEFI that ran poorly .Replaced every sensor, the ECM, TB, idle air bypass, TPS, plugs, wires. It still ran like crap. Converted it to carb and it ran great. Guessing wear in the engine caused it to be outside the peramaters the ECM could adjust to.
#37
Interesting....I switched from carb to EFI expecting BIG hp gains. Was disappointed, identical peak hp. What I did gain was better starting, great idling around docks, stronger mid-range and vastly improved fuel economy (economy..kinda of a funny word to use on 1150hp motors). Mine was a direct swap out 850 Pro-systems carb for a Fast throttle body and 8 injectors off fuel rail into intake port. Everything else was the same (intake manifold, massive intercooler,M4 Procharger)
#38
#39
#40
With EFI and speed density systems basically has the calibration program for every rpm thru out so once the internal vacuum and or intake air changes within the engine in any shape or volume form - the ecm can not adjust outside of the parameters the sensors are imputing / feeding the ECM for the corrected outputs.
Basically the ECM can not adjust for parameters that are outside of its calibration / tune.
