If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 4 of 15 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 143
  1. #31
    Registered WARPAINT's Avatar
    My Boats:
    1994 36 Apache
    Join Date
    Apr 2002
    Northeast MD
    Nooooooooo Prooooooblem!I tow my 8000 lb 28 APACHE with a Mazda Miata
  2. #32
    Registered bajadude's Avatar
    My Boats:
    340 Sundancer with 8.1s, formerly 1999 33 Outlaw HP500s
    Join Date
    Apr 2002
    Boca Raton, FL
    I think it's gonna leave a little yellow mark..somewhere..
    ... and big brown stains somewhere else
  3. #33
    I wouldn't even try that with my H1. It takes a 1 ton dually to tow my 35'. Good luck
  4. #34
    Registered Eman's Avatar
    Join Date
    Jan 2002
    Cincinasty, OH
    Lightbulb BIG KAHUNNAS
    Anything over 8500lbs. without a dually is asking for it! Let's just say for instance, The brakes stopped working....Make sure you tell him to duck when the blenders come past!!!!!!!!!!! [COLOR=limegreen]
  5. #35
    Offshoreonly Advertiser Offshoreonly Advertiser Mbam's Avatar
    My Boats:
    1972 Cigarette 36 race
    Join Date
    Mar 2001
    Pompano Beach FL, USA
    Well, I can tell you from personal experience that big boat and short truck = boat on side in grass. Years ago when I was young, 1981 or so I used to tow my 36 cig around with a 1975 Blazer, this was a full size one, you know the same sheet metal as a Dually or Suburban. Equalizer hitch, built trans, big block. Had no problem as far as getting the rig moving but every lane change or passing truck was an adventure.
    My buddy Jim Gaffrig (god bless his departed soul) was driving, we were heading down to Ft Lauderdale for our annual migration just outside of Bowling Green Kentucky when I woke as the whole rig was oscillating back and fourth across all 4 lanes, it did this a couple of times, worse on every cycle and BAM we slid sideways into the median. The boat wound up on it's side, the Blazer almost went over. The trailer really did a job on the rear quarter and tailgate.
    The good news is that we weren't hurt, and much to my amazement the only damage to the boat was grass stains on the cover. We did however brake a few bottles of the 12 cases of champagne we had in the cockpit.
    12 hours later after straightening the trailer axles, new wheels, new front spindle on the truck and a bit of swearing we were on the road again, moving much slower this time.
    That was the last time the Blazer pulled that boat.
  6. #36
    Registered Cattitude's Avatar
    My Boats:
    '97 Scarb Thunder, '06 Formula 330ss for sale
    Join Date
    Jun 2001
    Tulsa, OK, Grand, Beaver, LOTO
    HFN- He's f'n nuts!!!
    The H2 is actually stouter than a tahoe, has a beefier tranny and i think a 14 bolt rear but it is still no match for that setup.
    One thing that helps (but it's deceiving) is that with the very short rear overhang the hitch weight gets a lot closer to the rear axle, making it handle more like a gooseneck. With that said it probably tows better than a lot of other rigs- at its weight limit.
    The short overhang also makes it look like it's handling the tongue weight well even though it may have way to much on it.
    He's asking for trouble if he tows that boat out of the boatyard!
  7. #37
    Forum Regulator VIP Member Sydwayz's Avatar
    My Boats:
    37' Active Thunder AVH; 17' Speedliner Cat OB
    Join Date
    May 2001
    With all of that weight right behind the rear axle; I would be surpised if at a quick take off, that H2 does not do a wheelstand. I forsee a giant teeter-todder effect.
  8. #38
    Platinum Member Platinum Member Jassman's Avatar
    Join Date
    Oct 2000
    I know this was probably meant as a joke, but, Just remember, lifes too short, enjoy that Tiger, we have had enough boating accidents and fatalities this year, I wouldnt want anything else to happen.
    THE CONCENSES ARE: NOT A GOOD IDEA!!!! Building composite fishing and pleasure catamarans.
  9. #39 Charter Member Mrgoodwrench's Avatar
    My Boats:
    1998 American Offshore 2600
    Join Date
    Oct 2000
    LBC, So Cal. Where else?
    Might want to think about a Topkick.
  10. #40
    Let Thou Educate !!!!!!This H2
    What Jeffrey failed to tell you was that this H2 is being equiped with an Eaton Supercharger, new Computer, and exhaust, this will boost Horsepower to 470 and Torque to about 580lbs.
    For those of you that havent stood next to an H2, its about as wide as a dually and has much more stability in the front. It also weighs more than a 3/4 ton Suburban 4x4 at 6700lbs, shares the same transmission, and has a more intense frame structure. The transfer case is a Borg warner, with a crawl ratio of 33.1, running on a set of 35 12.50x18 Mudders!!!!!!!
    So Common guys, I think I'll wait a couple of hours for you to CATCH UP! before I order you a Vodka Cranberry while im waiting for you at the London Bridge Hotel staring at my Tiger in the water!
Similar Threads
  1. New H3 Hummer w/ V8?
    By wrinkleface in forum Trucks, Trailers and Transportation
    Last Post: 11-04-2007, 09:18 PM
  2. Towing cap. h1 hummer
    By Velocity Tom in forum General Boating Discussion
    Last Post: 09-26-2007, 09:27 AM
  3. hummer towing capacity
    By poolshrk in forum Trucks, Trailers and Transportation
    Last Post: 07-28-2007, 01:25 PM
  4. Towing with an H-2 Hummer
    By Bad Kittie in forum General Boating Discussion
    Last Post: 09-12-2004, 08:22 AM
  5. Towing with a Hummer H=2
    Last Post: 09-06-2004, 04:16 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
