School me on Bravo identification.....
The bravo on my resin bucket has no stickers/numbers left. I need to order a lower for it. It does not have the lube reservoir in the bilge. The lower has the oil drain in the bearing carrier not on the bullet.
Whats confusing me is I have heard oiler vs. non oiler... with the non oiler having no reservoir and the drain on the bullet.. So what the hell do I have?? and what lower do I need to order???
I have heard its possible to put an oiler lower on a non oiler up with some modification, whats the modification??
Drop the lower and you can look and see, in the big water passage there may or may not be an oil passage 1/4" in diameter or so. With the oil drain behind the prop it should have the oil passage.
