Driving advice for a 99 Daytona Eliminator 28 TD
#31
SORE MEMBER
1 Post
Checked timing yesterday, I have 22 degrees initial timing and 50 degrees advanced timing!!!!!!! Holy smokes that's way to much advance. Checked both sides, same on both. Stock GM hei dizzy's, ATI fluid dampeners with timing marks stamped all the way around, and a standard non adjustable timing light. Motors run perfect, and can't believe they are even still alive running this much timing for two full seasons.
#32
I double checked both motors because I couldn't believe my eyes!!! I am picking up a new timing light tomorrow to verify. I have to believe this much advance was costy me hp and speed....? Thankful at this point I haven't lost a motor. Not sure how this is possible if they really are advancing that much.
#33
#34
[ATTACH=CONFIG]545488[/ATTACH]
I was interested in this boat and found this pic on my phone yesterday. Two of these hanging down to be costing him speed, that is the most piss poor installation of a pickup that I have ever seen. I had a text conversation with Rob last night and made him aware of them. On a non innercooled or NA motor with bravo type drive I see no need for them. Sucks he has 2 holes in the bottom but eliminating those is some cheap speed.
#35
#36
Thank you for the offer Smitty!! I am going to try and figure out this timing thing, and the water pick up situation, and then see where we are at before I go changing anymore of my setup. I have determined I have 1.36 drives, and the props I have should be really close if I can get the rest of the boat dialed in. Smitty could 50 degrees of advanced timing be slowing me down? I realize I am lucking the motors are still in one piece, but did it cost me power up top???
#38
SORE MEMBER
1 Post
#39
Yeah those pickups are super long, for sure robbing you of speed.
I had the same style pickups on my 28. Mine were flush to the hull in the front and about .5" in the rear. had plenty of water pressure.
I would think a cut off wheel would be able to get them trimmed down enough without taking them out.
MP
MP
#40
