yamaha or seadoo
#32
have had sea doo's my entire life and i cant say enough good about them. they all have their little problems but i would find a 08 or newer 215/ 255 hp model. if you're going to pull the trigger on a new machine then i don't think it matters what you buy because they are all nice. with todays technology you really cant go wrong.
#34
With the supercharged models how many hours are you going before the second rebuild if any of ya have gotten that far. I know the first rebuild I'd recommended at 100 hours.
#36
Second, there has been some misinformation in this thread that I hope I can clear up and also add some useful info for you all.
1) Yamaha supercharged models started in 2008.
2) Seadoo superchargers have been practically bulletproof since 2009, and the recommended rebuild is every 100 hours.
3) The Yamaha SVHO 2014-2015 has been experiencing a number of timing chain failures. The 2016 model is updated. I would not recommend at 2014-2015 without extended warranty.
4) The Seadoo supercharged skis from 2004-2006 had exhaust valves that are prone to failure (moisture causing rust, then breakage) and weak flywheel bolts that can fail.
If you are going the used route, I recommend a Seadoo 2007 and newer, with supercharger that has been rebuilt within the last 100 hours, or a Yamaha 2008-2013. The Yamaha motor has a noticeable amount of torque advantage compared to the smaller Seadoo engine. My personal choices for each brand are the Seadoo RXP-X 260 and the Yamaha FX SHO. If you are going brand new 2016 I would get the Seadoo RXP-X 300 or the Yamaha FX SVHO. They are the most versatile craft from each brand in my professional and personal opinion.
Keep in mind that all of this information is geared towards the performance enthusiast. If you want to ride leisurely and don't need a craft that goes 70 MPH then there are cheaper and more reliable choices that fit those needs, such as the Yamaha FX, VX, and Seadoo GTI/GTX.
#39
SORE MEMBER
1 Post
Hi guys, first off, thank you speicher lane for sharing my website!
#40
