what to believe ?
look at RPM run times and then add all up
PCM could have been changed out even from 496 MAG to a 496 HO MAG not uncommon or they needed a new / used one however. Hence from a lower hour PCM
Also top dress cover on the engine changed as well to show HO MAG. You can verify all this by engine serial number. Located down at the starter and or on the original title depending on State titling / paperwork
Get all serial numbers - engine - drive and transom assembly and have a dealer run them and or Merc also all stickers on the PCM and or other stamping on the PCM. Merc can tell you MANU date and cal.
The St. Lawerence is brackish/salt water until the locks at Montreal. He is on the ocean side of the locks. Unless it's a smaller boat and lake driven..... My experience with that area is salts and poorly if ever flushed.
