Moving Hydrohoist
Old 09-26-2016, 01:27 PM
TYPHOON's Avatar
We have several of them at our club and no one takes them apart. They all found old boat trailers and modified them with 4x4 post. Back the trailer in and float it onto the trailer and store it as a complete unit. This only works if you don't have to go far to store it but sure make it very easy to pull out and put back in.
TYPHOON is offline
Old 09-26-2016, 01:42 PM
I'm thinking after floating it over, I'll dunk my 20 foot car trailer and bring it on land, then start the disassembly. Could pull it up but don't want to damage the tank, but could also have some plywood to lay under as it goes. From what I'm seeing, the 10 and 12 K fiberglass tanks are 23 feet long, so should get away with flags on the ends for transport
AllDodge is offline
Old 09-26-2016, 02:04 PM
Charter Member#330
MrCIG's Avatar
Just sold mine on Saturday, my marina had a pontoon trailer they used to get it out. Then 1989Mach1 and his brother Don started to un bolt and the marina lifted everything on to their boat trailer with a tractor with forks on it.
An impact will make it quicker
We were done in 2 1/2 hours
That Ron and Don hope your ride home was good
Mark
Attached Thumbnails Moving Hydrohoist-img_6289.jpg   Moving Hydrohoist-img_6288.jpg
MrCIG is offline
Old 09-26-2016, 02:27 PM
That's some long tubes. You bring up a question, wonder how heavy 23 foot tubes are?
AllDodge is offline
Old 09-26-2016, 05:03 PM
Use ratchet straps to tighten something like a boat cushion over the holes in the bottom. Without covering the holes, if the lift moves at all, it can begin to take on water, get lopsided, and then go over. Don't ask me how I know, but covering these holes is better than pulling one out of 15 feet of water!
36Tango is offline
Old 09-26-2016, 05:05 PM
Thanks, an ounce of prevention kind of thing, well worth the trouble for this newby mover.
AllDodge is offline
Old 09-26-2016, 09:39 PM
On my 12k hydrohoist the tubes are 32' not 23'.
W900 is offline
Old 09-26-2016, 09:46 PM
Neno the mind boggler
glassdave's Avatar
On my 12k they are 23'
08 OPA High Points Champion
glassdave is offline
Old 09-26-2016, 10:08 PM
I believe my 12k lift has 32ft long tubes
1989mach1 is offline
Old 09-26-2016, 10:11 PM
Mark
The ride back was not bad everything sayed in place.thanks
