Chaudron SV27
Beautiful!
Are they social ? Facebook? Instagram ?
Beautiful!
Hi!
https://www.facebook.com/aaron.ciantar.5?fref=ts
Aaron Ciantar is the main man behind Chaudron if I am correct. I have been in contact with him re testing one in Malta.
Cheeers, Toffen
Cheeers, Toffen
HI!
I have followed Chaudron for some years. Especially since they are heavy into racing against Outerlimits, Fountains, etc offshore in The Mediterranean. They have won several races with their 40-42 footers.
They have been building high performance boats for many years. In the beginning smaller speed boats between 22-30 feet. They were very like, if not identical, to the UK built Phantom boats. I have a original Phantom 25 from1985, and their Chaudron 25 was 100% alike. However, the boat builder of Phantom ceased his production end of the 90-ties if I remember correct. Anyway, their new Chaudron PRO 25 has a new 2 step bottom (mine is straight V) and very fast. It runs 86 mph with a single Mercury 300XS. https://www.youtube.com/watch?v=QoWxf4d4zV8. http://www.chaudronpowerboats.com/
The all new SV27 seem to combine the design of bigger boats with the smaller Phantom like models. I especially like the narrow beam.
Cheeers, Toffen
Cheeers, Toffen
Hi!
Thanks! Me too discovered Malta due to Chaudron. Holiday in the spring it will be 😎
Got a message today that the red boat with twins will be tested this weekend.
The white one is waiting for a side mounted steering set up. Top speed so far has been 85 mph. Estimated top speed is 88 mph. Not bad for a 27,5 feet hull and a single 400 hp engine.
I will ask if they will test twin 300xs 😀😀
Cheers Toffen
Cheers Toffen
HI
The switches on the steering column I presume are powertrim for each engine on the red boat, and for the white boat powertrim for the engine and adjustment of the hydraulic jackplate. I did the same when I had 2 x 2.5 EFI SS engines on mine, and as the white one now when running one engine. Enclosed picture of the Phantom, and some newly pictures of the white Chaudron interior. Nice!
Cheeers, Toffen
Cheeers, Toffen
I found the Chauldron on Youtube about a year back. They reminded me of your Phantom Toffen. I found the Twister and the Argo when Adam Mckeon posted videos of his Argo.. I'm now leaning towards the 25" Twister or Yuka. I'm looking forward to hearing the results of your new 400R Toffen.
Cheers to you T
Cheers to you T
Cheers to you T
Cheers to you T
That s because chaudron started whit copy a Phantom and then devolp them further whit steps and other decks and dashes which they really make them nicer !
Hi!
You have a point Bor
Below you will see Chaudron Pro 25 and its nearly identical to my Phantom 25. Especially hardcore Phantom owners been critizising Chaudron as a splash. That said its nearly 20 years ago the last Steve Baker Phantom was made. However, Chaudron Pro 25 has a new two stepped bottom, and approx 10 mph faster than my ol lady Phantom 25. So thats an achievement
Its no question about the build quality. I considered to buy a Pro 25 with the same design as my Phantom, put a 400R on it and run like hell down the Fjord. But I was recommended to look at the new SV27 - and this is my new boat I think. A little longer, still narrow beam. fast hull and a cabin. And nice design
Cheeers, Toffen
Cheeers, Toffen
