I like this will it work in my boat?
Have been looking at a keyless go system for my boat, however, there are very few manufactures out there that offer them. I ran into this today, called the company and plan to order tomorrow. My question is will this work with my boat and are there any downsides to this application. Thanks
http://www.digitalguarddawg.com/14-products/marine
I would look into the ones used on ski boats. I have seen them where you enter a code, then you can start the boat. You do not need to worry about losing the key float, or someone accidentally starting the boat.
I agree with Perlmudder. Bought my boat with the code instead of key ignition. No key to lose or forget. Enter code push Run for the blower. Hit start. Bam! Then push Stop and have a cool one. No brainer system which is perfect for me.
There is a separate RUN button from the START button. The switch is wired so that when you push RUN the blower turns on and stays on while the engine is running. Also you can't accidentally hit the Start button. The RUN button has to be pushed first.
