If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 6 of 6
  1. #1
    jb is offline
    Join Date
    Oct 2000
    Syracuse, New York
    Drive temp guages...???
    Why does Manufac. not put a drive temp guage standard on High performane applications?
    I am led to believe that drive temp directly relates to a drive breaking. Not to mention too much HP and doggin the boat hard.
    Wouldnt a guage give you an indication someting is near its breaking point???
    Also told merc wants NO guage so you CAN break it!
    set me straight
  2. #2
    Registered mr_velocity's Avatar
    Join Date
    Apr 2002
    Not so sure about that. I've heard a few drive guys say they have never seen a heat related failure. For Bravos is the constant loading/un-loading of the drive.
  3. #3
    Velo !
    Load & Unload directly create heat through stress .... Heat is a byproduct of energy, etc, etc ............Come 'on man where you head .......
  4. #4
    Charter Member Charter Member Raypanic's Avatar
    My Boats:
    Formula 400SS Eliminator 236 Eagle XP
    Join Date
    Oct 2000
    Lake Orion, MI. USA
    I have them, I like using them, If one drive is not consistant with the other it will clue me in there may be a problem brewing. Someone else just blew a drive because of little or no fluid. I think the indicator would of helped. Either high temp or no temp would signal a fluid loss.
    If drive temp is not an issue why do they sell so many drive coolers? It couldn't all be bunk...
  5. #5
    Toxic FORMULA Platinum Member mopower's Avatar
    My Boats:
    1989 Formula SR-1 272 t/540's
    Join Date
    May 2002
    pitman nj
    A Merc mechanic friend of mine sez a drive shower is the cheapest insurance you can buy
    You can never have too much horsepower or money...It's just hard to have both.
  6. #6
    Registered VIP Member Smitty's Avatar
    My Boats:
    2000 Baja 36 Outlaw
    Join Date
    Apr 2001
    Hawthorn Woods IL
    I have had a drive shower (Innovative Marine) on mine since new. I have run it hard always and for the last two seasons I have run 600 hp. with no problems or metal on the magnet. This drive shower is a thick billet type top cap that IMHO strengthens the stock top cap from flexing when you run it hard. I also change fluid every 25 hours along with motor oil. As with ANY internally lubricated machine, heat is the killer of fluids. Heat weakens the fluids thus reducing the gap between things causing metal to metal contact. When the fluid is compromised, that's when things break/wear down.
    I feel a drive shower is a requirement for any performance boat and that a drive temp guage is just a way for you to keep an eye on things and practice preventative maintenance by watching temp and changing fluids often. A case of gearlube per year is alot less than a drive repair!!
Similar Threads
  1. drive temp.
    By Ken N in forum Drives and Lower Units
    Last Post: 09-20-2008, 12:34 PM
  2. Livorsi Drive Temp Senders?
    By CheckedOut in forum Drives and Lower Units
    Last Post: 06-24-2008, 12:40 PM
  3. WTF are these temp guages?
    By GO4BROKE in forum Sonic
    Last Post: 08-22-2007, 07:29 AM
  4. Monitoring drive oil temp prolong drive life?
    By Canada Jeff in forum Drives and Lower Units
    Last Post: 07-19-2007, 02:38 PM
  5. Drive temp question?????
    By Fast Frank in forum General Q & A
    Last Post: 08-19-2004, 06:28 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
