Donzi ZR. Ever seen one with a bimini?
ToMorrow, thanks for the pics, nice boat, bimini looks like it belongs there. Like the way you can move it back so it will lay down behind the hatch, not sure I could do that because I don't have the flexibility of the windscreen rail like you do. Can't lie it down across the top of the rear lounge either because the lounge lifts up in one piece with the hatch. Something to work on.
And I see we have another Zee-R among us......
RR
RR
A lot of west coast companies use these low profile Bimini mounts. That way you can put the Bimini anywhere you want and when you take it off, it's not as obtrusive.
Bimini Mount Set Flush - Marine Industries West
When I purchased my 35zr it had DUAL Bimini tops. (ashamed)
They stored inside of the engine bay on two nicely made stainless racks that held the tops against the bulkhead. I have had them on up on Ebay for a while now. Just not my speed and the brackets would wreck you if you missed your footing when getting in. I still have the front strap rings just ahead of the windshield and use them along with two small loops on the rear to hold my ANCHORSHADE made by TaylorMade.
If you like the look of it...go for it. I have a pair super cheap to sell. However the anchorshade is a much more pleasing look for a performance boat like a ZR
Dont suppose yo got any pics? (Set up or stored) Do you still have the eBay ad? If you have a link maybe I can see a pic.
Next silly question, I've never seen a ZR of any size, I'm assuming the 35 cockpit is quite a bit bigger than a 27, hard to tell from photos. If they're the same size, I might try to work a deal with you. Sounds like it might look God awful but it's the best way to protect from the heat here even knowing I'd have to drop it down for higher speeds.
Thanks for the help,
RR
Drive to arrive alive!!!
Like this one? 4 axles on a bolt together trailer for a 342 seemed a little silly to me.
It's taken 5 months but I finally have a nice bimini......!
Sunbrella of course and all mountings are quick release and thru-bolted. The first effort had just over 6' headroom and looked awful. At 45-50 mph one of the quick release fittings 'released quickly', possibly due to the length of the support, too much side to side movement. Decided to lower it all by about 8" which is fine when seated and cruising which is most of my boating. Standing up I have to sit back in the bolster and lean forward to the controls a little or fold the top down.
Probably the most expensive Bimini top ever made..........(twice.......!)
Its still a bit ugly but aren't they all?
Doesn’t look bad. The way it’s nice and flat matches the ZR lines. Looks relaxing under there too.
If you drink fosters on the boat, id say it’s zed-r
Not really a comparison because the Fountain was a 34' CC but.......
both boats impressed me for very solid build, almost heavy. Hitting a wave or dropping into a hole, no rattles or noises on either. I'd say they're about the same. Overall finish, Donzi might have the edge but it's not a real comparison. Both boats live up to their name!
RR
RR
