Best Boat cleaner / Wipe down product
General question from a shine rookie- will these quick details, paint gloss, and the other quick shines help extend the life of a base coat of Collinite (or whatever) or remove/replace with a quick shine that quickly disappears?
I've used Meguiar's paint sealant which gives a quick, easy, wet look shine over a good wax base and am wondering if I was "p@@ing upwind and removing that base coat.
Quick note- the real acid the pros use in the industry to remove the real hard water spots, is not something the general public is suited to ever use.
Padraig
Received 3,020 Likes
I've used both the Boat Bling Quicky Sauce and the Teague Shine and like them both. The quicky sauce is a carnuba based wax. It comes out thick and you have to work it a bit but you get that real wax'd look. Also, because it's a wax it will leave that white dust on darker painted areas if you miss it or it's in creases. It's a great, easy way to get a real wax in a bit faster than bringing out the cloth pad and various waxes.
The BioKleen / Teague Shine is a little more liquidy and less waxy. It is an absolutely GREAT quick detailer that brings out a nice shine, is super easy on and off, doesn't leave streaks and works on paint, fiberglass, glass and other surfaces.
I really like both, they both have a little different use. I use the Teague shine to quickly wipe down and keep that continuous shine going / take away water spots, etc. I use the quickie Sauce when I want to spend a little more time and lay a base coat of wax down easily. Both great products and super affordable. You can buy both of them from Teague FYI.
Tank
Tank
I mostly use the cheap Turtle Wax Detail Spray every day to clean the bugs, bird poo, water spots, and scum line on my boat. One of the best things I've used and half the price along with being readily available. It even enhances the shine I find like it says on the bottle. Dries quickly, no streaks, spots or anything. Works great on glass even. For $4.99 a bottle, I use it constantly. Every 2nd or 3rd time out I use the Turtle Wax Quik Wax spray. That also works fantastic and keeps things nice and non-stick.
I'm pretty particular about cleaning products and I try other stuff occasionally, and keep coming back to the cheap ole Turtle Wax.
