They are out
1 Attachment(s)
The engines are out---- finally- been busy
1 Attachment(s)
Pic #2
What the heck are you using to pull the motor ? A crane ?:)
Oops I didn't see the second picture !!!:D Until after I posted |
best friend runs a 17 ton 150 ft crane:D
Now that's a good friend to have :D
The paint is stock and it is a 92 boat.
Real Cool Tinker .:)
Tinkers boat
Hi looking at your pics and I see Wellcraft used the same still of swim step on my Nova as your. Yours is oviously bigger though. Just had to say something. Charlie
Now that they are out what are you going to do to them over the winter?
Macdad260-- I haven't decided yet. Either turn them into 540's or go with a set of Jim V. heads. Both should get me the about the same amount of HP. The least that will happen is fixing the leaking tiller shaft seal on both drives and freshening them up. I want to change to a big hydraulic roller cam also. I also want to increase the compression to 9.5 to 1. Also need to finess the ports on the heads to match the intake manifold. It isn't quite right but it was pretty close. ( Was in a hurry when the engines went togeather 6 years ago) The heads were all assembled when I found that the ports of the intake have sharper corners than the heads do.(stock- Jim V -modified heads with DART intake)
