Head Gasket debate, more info requested.
Fel-Pro has a head gasket with a stainless O-ring (copper for alum. heads) intended just for forced induction. It's quite expensive but seems to work. I have had them on my turbo'd 454 for 15 years and 1200 hours and it still runs great. I can't remember the part #, but back in 1987 when I built the engine, I consulted Fel-Pro and had to special order them.
Studs provide a better/more even clamping force and because of the material they are made of are less likely to allow head to lift off block under firing. Yes , this really happens but is so slight, especially in a blown application where twice the air/fuel mix is being ignited.
Bryan,
Don't go with Gaffrig "Coolcharger" as it does not put out near as much hp as a procharger or Gaffrig's new "Extreme Supercharger". Mike Livorsi had a former Merc employee, that started his own hi-perf shop, reprogram the computer. The entire system has worked flawlessly for me so far. They were even able to program into the computer a warning for high fuel/air mix temps in case of intercooler blockage issues.
Give Ron Harris a call at Livorsi Marine as he helped in the design of this system. He can certainly give you additional input - he is on OSO occasionally as Cig28SS. Phone 847-548-5900 ext. 223.
Tim
ps. 170 hours so far with original head gaskets - I know I should probably change them
Tim
NOT TRYING TO ARGUE BUT STUDS ARE THE SAME MATERIAL AS BOLTS !!!AS LONG AS THEY ARE GOOD AFTERMARKETS LIKE A R P 'S,,,,,THEY CLAMP BETTER DUE TO SEVERAL REASONS THE MAJN ONE IS THE THREADS ON THE NUT SIDE ARE FINE THREAD SO IF YOU TIGHTEN BOTH TO 50 LBS THE FINE THEAD IS TIGHTER DUE TO MORE LEVER ACTION ,THE SECOND BEST RESON THEY CLAMP BETTER IS THEY DON;T TWIST THE BLOCK SURFACE LIKE BOLTS
ALSO JUST THINK IF THE HEAD LEFT THE DECK SURFACE ,EVEN SLIGHTLY,,IT WOULD CONSTANTLY LEAK COMBUSTION BYPRODUCTS ,IF IT LEAVES THERES A BAD PROBLEM (DETONATION)
BOLTS WORK GREAT WHEN ISTALLED RIGHT, STUDS DO WORK BETTER BUT MOST APPS.DON'T NEED THEM !
HOPE THIS HELPS
BRIAN,THE INNCONEL PART OF THE VALVE MOST OF THE TIME THE HEAD ONLY WOULD NOT BE PULLED BY A MAGNET AND REGULAR STAINLESS WOULD BE ATTRACTED !!!!
MOST VALVES LIKE THE INNCONEL ARE TWO PART THE HEAD IS INNCONEL AND THE STEM IS STAINLESS
VORTEC IS A GOOD BLOWER OR THE GAFFRIG UNITS
