If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
  1. #21
    My Boats:
    1949 Chris-Craft
    Join Date
    Mar 2002
    Orlando, FL
    Do yourself a favor and change the gaskets to Fel Pro.
    Also, use the studs. They clamp far superior then just plain ARP bolts.
    If you're going to do it, why not do it once and do it the right way??
    Make sure you seal the threads too.
  2. #22
    Platinum Member Platinum Member mcollinstn's Avatar
    My Boats:
    1991 F311SR1
    Join Date
    Sep 2001
    I've been told that at less than 10psi of boost on a BBC, that you should NOT use O-ringed heads. I have been assured that the O-rings are not needed at less boost and that unless a reputable pro does the machining for the Oring, that it is very difficult to get the grooves lined up perfectly... Also, if a motor goes into detonation, then if the head gasket doesn't let loose then the piston crowns will go or something equally soild will break.
    The procharger guys and all the builders I have talked to say that a good felpro loc ring gasket will hold up fine, and that if the motor goes into knock, then the gasket will be the FUSE and will (hopefully) let loose before major component damage.
    I see London, I see France...
  3. #23
    Donzi33ZX Gold Member BryanTuvell's Avatar
    My Boats:
    2003 Donzi 33ZX
    Join Date
    Mar 2001
    Suffolk, VA
    Thanks, GREAT info.
    But I have continued to educate myself the last two weeks.
    I have found the shop I want to do the work, build, dyno etc, we will leak down test each cylinder FIRST before charging the motor, in fact I may even postone the project if I have one cylinder off, since I am still under warranty.
    As explained to me several times, if all the cylinders are really good we may skip the head job and just move forward.
    Small steps then bigger ones.
    2008 F350 SWD 4x4 6.3 PSD + Donzi 33ZX
    Performance on and off the water!!!!
Similar Threads
  1. NH Speed Limit debate rears its ugly head - again...
    By DoTheMath in forum General Boating Discussion
    Last Post: 02-11-2007, 11:24 AM
  2. HP 525SC Blown head gasket AND head !
    By ur2slo in forum Formula
    Last Post: 08-17-2006, 10:01 PM
  3. Stratos Boat Info Requested
    By Formula Outlaw in forum General Boating Discussion
    Last Post: 12-28-2004, 09:24 PM
  4. aluminum head and head gasket info needed
    By traviss in forum General Q & A
    Last Post: 12-06-2002, 06:35 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
