If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 55
  1. #31
    Registered Flyinbrian's Avatar
    My Boats:
    24 Skater
    Join Date
    Dec 2001
    Fort Myers, Florida
    Re: Pinging
    Originally posted by Ratchet
    - - - - Pinging - - - -
    I thought this was a normal occurrence with these - lol. Mines been doing it for the longest time. I took it in when it was new (in 98) and they told me this was normal......C'mon, a little ping is usually followed by a big bang ! So I always ran midgrade. If I ran normal gas, it sounded like someone was dumping gravel into a pie pan !!!!!!!!!!!!
    I guess when it hitws about 100k, I'll change the plugs & most likely go to ngks, and maybe a couple of steps colder
    Brian - what did you do about the pinging (if anything) ??????????
    A couple of things-
    1. Open the hood in the dark with the engine running in the dark. The factory plug wires are junk.
    2. THIS IS THE BIG ONE. The 3.9 V6, 5.2, and the 5.9 all suffer from an intake plenum gasket leak. This leak is internal. When it leaks you may notice oil consumption. What happens is; The gasket on the bottom of the plenum leaks, vacuum from the intake pulls oil into the cylinders adding oil to the mixture. It also makes carbon build up on the pistons at a fast rate. So, more compression, less octane= pinging/detonation.
    To check=Remove the air cleaner assembly from the throttle body. Open the butterfly's on the throttle body. With a flashlight look to the bottom of the plenum. If it is wet, you have a leak. There is another test you can do with the pcv valve, I can post that later, but first check this way.
    You'll have others that will probably post here and tell you to run higher octane, install a lower temp thermostat, get a computer update, etc, etc, etc.....
    Don't do any of this until you check for the leak.
    If you have a leak, get the gasket and bolt kit from the dealer. You cannot reuse the plenum bolts.
  2. #32
    My Boats:
    one slow Fountain, one fast ice boat.
    Join Date
    Feb 2002
    Traverse City, Michigan
    The pinion gear bearing failed in my previous (1996) Dodge Ram truck. Some of the rollers within the bearing assembly fragmented. The rear end never completely failed but the noise got progressivly loaded. Repair cost was high due to labor. The bearings Chrysler used are Timken made in the USA.
  3. #33
    I just traided my 01 Dodge 1500 Quad cab with 45000 miles for an 03 Ford F350 Crew Cad with a 7.3. I didnt have any problems with my Dodge at all. I but a 3in lift on it also with 33" tires.
    My friend had a 2000 with a trans problem. They fixed it without any problem. I hear people all the time complaining about their Dad has 165000 on his and just last week he had to replace his fuel pump actuator....and a couple of sets of bearing in the rear end. He towes a Fifth wheel camper that weighs around 17000lbs so I understand the rear end needing a little atten. He is very pleased with his.
    I got rid of mine because the value was dropping fast. It lost $13000 in just over a year.
  4. #34
    My Boats:
    24 Skater
    Join Date
    Dec 2001
    Fort Myers, Florida
    Nobody is saying that all Dodges are junk. Just some of them.
    Some Chevy's are junk and some Ford's are junk too.
    Go to to look at TSB's and recalls for your specific vehicle. You'll see they all have their problems.
    My father has a 1996 Chevy HD 3/4 ton with over 150K of hard towing that has had minimal problems compared to my Dodge with half the miles, (towing lesser weight and distance), and two years newer.
    Anyway, just sharing my experience to try and help others before they blow their motor's.
    This is my third Chrysler product since 1995, I had some pretty nasty problems with all of them. From transfer cases, rear ends, intake plenum leaks, exhaust manifolds cracking, etc, etc....
    Even after all of the troubles, I would own another one. They all have their issues.
  5. #35
    Registered Ratchet's Avatar
    My Boats:
    94 31 Scarab Thunder
    Join Date
    Sep 2001
    Lake St. Clair
    Thanks Brian.........when I get a moment this week, I'll take a look.
  6. #36
    Registered SteveS's Avatar
    My Boats:
    Warlock 27WC F1-36
    Join Date
    Feb 2001
    Verona Beach, NY USA
    A guy I work with had his rebuilt 3 times under warrenty, the fourth time they replaced the housing because they found the shaft bores were missaligned.
    High quality **** there. I shouldn't talk, my daily driver is a 96 Intrepid ES and has been a great car.
  7. #37
    Official OSO boat whore Charter Member
    My Boats:
    8' row boat
    Join Date
    Oct 2000
    Mequon, WI
    Originally posted by ernie davis
    Sorry to hear about your diff. problems.
    If it were a Dana I would send you the parts!
    Daimler-Chrysler gave Dana the boot this year (m/y 2003) and
    gave the heavy rear axle buisness to American Axle Corp..
    American is apparently charging less for their be aware.
    Ernie @
    Dana Light Axle Div.
    My 96 diesel either has a worn out limited slip or has a open diff. Do you have a source for a new limited slip? Desperatly seeking traction...
  8. #38
    belly gasket, underside of intake manifold leaking /
    lots of pinging and where is all the oil going/i'll be taking my intake off this weekend &my rear end whines i'll be looking into that too i've heard that the special mopar gearlube is garbage.differential$250 gears$200 install kit$150 labor4hours hardly$2000
  9. #39
    Registered Pantera1's Avatar
    My Boats:
    Join Date
    Mar 2002
    My cousins brothers girlfreinds sister who went out with a guy from callamazoo had a dodge once and said it was junk ..
    PLEASE ..Ive had several dodge trucks over the years and if you drive em into the ground ..(like I do 180K on present truck).. Nothin beats a dodge .
    Can you say HEMI ?
  10. #40
    Registered fountain1fan's Avatar
    My Boats:
    162 scout flats 90 merc
    Join Date
    Dec 2000
    eden nc
    sorry chevy guys you have aam , and your ifs is worse than a dana alll alum all 2003 dodge heavy duty have aam soldnaxles . i hope they hold up . but ill drage your gm eay time you wount to hook up 2003 dodge qc 2500 ctd
Similar Threads
  1. 18,000 Miles & Counting
    By Dock Holiday in forum Baja
    Last Post: 11-15-2006, 08:28 AM
  2. Ford Expedition differential
    By mars in forum Trucks, Trailers and Transportation
    Last Post: 03-23-2006, 07:27 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
