If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
  1. #11
    I have a 02 Chevy 1500 ext cab 4x4 5.3 3.73, and I tow my 5000 lb boat/trailer with no problems. In the Tow/haul mode I have no problem at all with hunting for the right gear. With 4.10 gears it would be even better. I don't have any piston slap or ticking, I guess I am lucky. I average 17-19 MPG, 12 towing. Like you I was deciding between a Ford or Chevy and the engine/transmission of the GM made my decision. I have had 4 other trucks with the 5.7 reg cab , and the 5.3 ext cab will blow the doors off any of them.
  2. #12
    Charter Member#203 Charter Member Pete B's Avatar
    My Boats:
    98 Scarab 302 Sport
    Join Date
    Oct 2000
    Ft.Myers, Fl/ Atlanta, Ga/ Worldwide
    mine was lifted 4 in, with 35's on it, for the average run around truck with minor engine mods it rocks
  3. #13
    Mccolister and Deltoid have both pretty much described my experience with my 00 5.3 sierra 1500slt z71. I have 78,000 on it and have never done anything except change fluids. I have towed my 32 active thunder all over with it (7000 on the boat alone) I have also towed Tbones 02 38 top gun my only dissapointment was braking (with the top gun in tow, but 700 bucks on the trailer would fix that) I have 373's in the truck
    Mine does have the "GM power tick" but as mentioned it does go away @ temp. I have had the following gmc's
    96 x-cab 4x4 Z71 5.7l
    98 Yukon 5.7L
    99 1 ton Dually Low rider Crew Cab long bed 7.4L 2wd
    99 3/4 ton 4x4 Suburban with 7.4L
    00 1 ton Dually 2wd crew cab short box 7.4L
    00 Sierra 1500 slt 4x4 Z71 x-cab 5.3L
    I can honestly say empty this truck will hide from the rest of them (and my dad's 02 f-150 with the 5.4 or what ever it is)
    From the stop light the big block trucks would have beat it to about 50 mph and then it could hold its own while towing my 32 thuinder.
    just my experiences.
    If I was ordering one now i would pony up for the Denali so i could have the 6.0 and the bigger brakes.
  4. #14
    bn is offline
    Registered Platinum Member bn's Avatar
    My Boats:
    260 Formula SS
    Join Date
    Oct 2000
    Syracuse, NY
    I had a '99 1500 with the 5.3 and 3.73's. I towed my 29 Outlaw all the way down to Kentucky with it and had no problems. (I think that it was about 800 miles) It had plenty of power. As far as the constant shifting, the cure is to put it in tow-haul mode AND drive 3, not overdrive.
    I even towed my 35 Sonic with it the first season I had it. I don't tow very much normally and the farthest I took was about 90 miles. I've got a 2500 HD now with the 6.0.
  5. #15
    Registered Dredgeking's Avatar
    Join Date
    Apr 2001
    Lake Charles, LA
    i've had 3 z71 w/ the 5.3. good engine. a bit better than the last 350. now i run the 6.0 and like it too. gm has done a great job with the new engines.
  6. #16
    If you tow in OD you're gonna have alot more than the motor to worry about. Cruisin' at 65 pulling your pud maybe but anything more and you can kiss your motor and tranny good buy.
  7. #17
    My Boats:
    1984 Chris Cat
    Join Date
    Jul 2002
    Troy, Mich
    The 5.3 is a great engine for everyday use, good mileage and quiet.
    I do not have a problem with it hunting for gears, the tow/haul mode really works to calm that down.
    I do find it burns oil though, about a quart ev. 2000 miles- but I use Mobil 1 and synthetics aggravate this condition.
  8. #18
    Forum Regulator VIP Member Sydwayz's Avatar
    My Boats:
    37' Active Thunder AVH; 17' Speedliner Cat OB
    Join Date
    May 2001
    Daily driver and grocery getter with the occaisional 2000 lbs of towing; not a problem.
    Get a toneau cover for a little better mileage.
  9. #19
    250 sport
    I have a 2000 Z71 with 410 gears and I have had no problems what so ever. I pull a 25' baja and it does a good job hauling it.
  10. #20
    Registered BigMike's Avatar
    My Boats:
    2014 Contender
    Join Date
    Dec 2000
    SW FL, USA
    I tow with a 2002 Tahoe with the 5.3. The motor is perfect for a daily driver in a heavy truck. Towing is not bad. I only tow 3500 lbs and have no problems what so ever. No tranny hunting. Nothing. I do have the knock on start-up. My brother is the GM at a Chevy dealer and tells me it is piston slap (???). He said it is perfectly normal and every one he has driven does it. Mine has been doing it since 3000 miles.
Similar Threads
  1. New sierra out on gmc's homepage!
    By TeamSaris in forum Trucks, Trailers and Transportation
    Last Post: 03-08-2007, 10:23 PM
  2. Replacement parts from Sierra
    By joee in forum General Q & A
    Last Post: 05-10-2006, 01:43 PM
  3. '99 GMC Sierra not going into 4 wheel drive
    By Rookie in forum Trucks, Trailers and Transportation
    Last Post: 05-04-2006, 05:03 PM
  4. Merc/Sierra Impeller Part #
    By fred in forum General Q & A
    Last Post: 05-29-2003, 05:35 AM
  5. Anyone with bad experiences with ANY motor oil?
    By kook in forum General Q & A
    Last Post: 07-08-2002, 07:08 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
