OFFSHORE ONLY...this is driving me NUTS >
Old 12-19-2002, 07:20 PM
packinair
Default OFFSHORE ONLY...this is driving me NUTS
every time I move about the site I get a script error on EVERY page.. I am using AOL 8.0. I was getting at home and now on another computer... I am getting:
LINE 3
CHAR 9
ERROR: Syntax error
CODE 0
Just letting you know
PS... I still have not forgot the bannana thing
Old 12-19-2002, 07:24 PM
PhantomChaos's Avatar
Yep....it's a script error of some kind.....will either get better or worse after the "upgrade" tonight!
PhantomChaos is offline
I use internet explorer and no problems here
Scooter is offline
Old 12-19-2002, 07:26 PM
I'm using IE 6.0, and the error is not apparent, but in the bottom bottom left corner, you probably see a small yellow triangle with a "!" in it........
Old 12-19-2002, 07:30 PM
yes i do, thanks for pointing that out, what does it mean
Scooter is offline
Old 12-19-2002, 07:37 PM
There is an error onthe page.....double click it and it will give you info on the error (just as described above).
Old 12-19-2002, 07:41 PM
Charter Member #927
Payton's Avatar
It means they are watching.
Put a finger over it. or better yet cover your head with tin foil. That is the only fix I know of.
Payton is offline
Old 12-19-2002, 07:44 PM
cute payton thanks for the advise, thanks nort it said the same codes as listed above, o well still works for me
guys have good holiday
Scooter is offline
My EX got the Sleekcraft
gdfatha's Avatar
Talking Compassion...Compassion...Compassion..
gdfatha is offline
Old 12-19-2002, 07:46 PM
HyperBaja's Avatar
A syntax error is when the programmer enters the source code with errors in it. Ex is forgettign a semi colin or something simple like that.
HyperBaja is offline
Quick Reply: OFFSHORE ONLY...this is driving me NUTS
