If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Question salt water boats
    how much and what kind of damage does salt really do and how much should a salty be discounted apposed to a fresh water boat?
  2. #2
    Platinum Member Platinum Member CigDaze's Avatar
    My Boats:
    Cigarette 35 Cafe Racer
    Join Date
    Jun 2001
    St. Petersburg, FL
    Most, if not all saltwater damage is in the form of metalic corrosion. The boat itself isn't too much affected, however washings and waxings should be performed more frequently. Salt will accelerate gelcoat oxidation and deterioration.
    Saltwater damage is really no worse than freshwater damage other than the damage is done a lot faster! It consumes more time and maintenance to prevent damage and prolong the life of your equipment.
    Just like anything else it comes down to how well you maintein your gear. Replace zincs regularly, flush religiously with some kind of "salt-away" agent and always have a fresh coat of anti-corrosive spray on everything in the engine compartment.
    Lakes and rivers also have minerals and ionized particles suspended in the solution, the only difference is that it is much weaker.
    Put an iron bolt in a bucket of saltwater and lake water....both will rust away in time, the salt just faster.
  3. #3
    Join Date
    Dec 2000
    Solomons Island, Md
    Ditto to what BD said but I also think much of the damage is done while the boat is still new and in the possession of the dealer. I donít see too many dealers rushing back to flush engines immediately after giving a demo ride in salt water like most owners do.
  4. #4
    Registered SpectreBoy's Avatar
    Join Date
    Oct 2002
    Grove City, Ohio
    Look under the dash, and see what it's done to the wiring, the back of the gauges, look under the motor covers if outboards and check the plug ends and all elec. stuff, same with an IO look at everything close, I looked at several salt water boats before I got mine and the people who salt water boat don't think anything about it, but never having a boat in salt like me, their idea of nothing damaged and mine is different, it's all in your perspective..........My friend went to Fla. for one winter and had his boat in 3 or 4 times, washed it down everytime, and then it sat in the salt air for 2 months, the following summer, all the head bolts were green from corosion, the spark plug wires had to be replaced, they had been eatin through and weren't making a good connection. I think there worth a lot less, but who cares what I think.
  5. #5
    jb is offline
    Join Date
    Oct 2000
    Syracuse, New York
    i pass unless its priced much less to figure in replacing everything
  6. #6
    Registered SPITFIRE's Avatar
    Join Date
    Oct 2002
    Boston Ma, Charlotte NC
    living on the ocean and having had several boats, my luck has been the ones i have bought from people on lakes have had the most problems. as far as the corrosion on the external parts, it sure doesn't look good but doesn't necessarily mean that the parts are no good. its is also true that metal will break down in salt water faster than fresh but it also the oxygen in the air that really accelerates it. i guess my opinion is that a fresh water boat is going to probably look better after time than a salt water boat but with proper care and maintenence i wouldn't be afraid of one. to answer the question, i would think about 10% less for an ocean boat due to the probable cosmetics involved.
  7. #7
    Banned cuda's Avatar
    Join Date
    Sep 2001
    Deland, Florida
    Be aware that even if it looks good on the outside, corrosion is occuring on the inside. Areas of particular concern are the exhaust manifolds, risers, and heads. I've taken off exhaust that didn't look that bad on the outside to find little left on the inside. If an engine is run in salt for 20 hours or so, even changine to closed cooling won't help much. The salt permeates the cast iron. I took a set of heads off once that I was replacing because they were shot. I left them on the porch for a few weeks. The next time I looked at them, there were actually little mounds of salt about a half inch tall built up around the water passages where the moisture in the air leached the salt out of the cast iron. I had a picture of it, it was unbelievable. I can't seem to find the pic at the moment, but if I do I'll post it.
  8. #8
    Join Date
    Jul 2002
    Also salt water boats from warmer climates will see year round use and more exposure to the sun.
  9. #9
    Registered Frequency's Avatar
    My Boats:
    '91 Carbon 70 Cafe, 3370 Pursuit
    Join Date
    Aug 2001
    Peoria, IL & FMB, FL
    Year 'round use. Wish I had THAT problem!
  10. #10
    Member #2 ....Jeeezz Charter Member cigarette1's Avatar
    My Boats:
    Toy Boat - Toy Boat - Toy Boat
    Join Date
    Oct 2000
    Kicked to the curb
    Let's see ..... which one would I rather have ?
    A POS freshwater boat
    - or -
    A POS saltwater boat
Similar Threads
  1. speed in salt water / fresh water
    By jeff32 in forum General Boating Discussion
    Last Post: 01-09-2006, 07:21 AM
  2. Salt Water Boats
    By formula271 in forum General Q & A
    Last Post: 04-04-2005, 08:25 PM
  3. Salt water vs Fresh water
    By Stormrider in forum General Boating Discussion
    Last Post: 03-04-2005, 09:29 PM
  4. salt water boats???
    By uneasy-rider in forum General Boating Discussion
    Last Post: 08-05-2004, 05:36 PM
  5. Salt Water??
    By flylevel in forum General Boating Discussion
    Last Post: 07-18-2002, 11:43 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
