If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 7 of 7
Thread: 2004 corvette ?
  1. #1
    Platinum Member Platinum Member 26sonic's Avatar
    My Boats:
    boats, cars
    Join Date
    Feb 2001
    poughkeepsie, ny, usa
    2004 corvette ?
    anyone have info on the 2004 corvette ? is this the year there changing the body style again ?
  2. #2
    Chevy-Harley fan Charter Member gmhdfan's Avatar
    Join Date
    Mar 2001
    Orlando, Fl. USA
    Not sure but Cadilac is building one with the northstar motor in it. Building it next to the Vette line in Bowling Green plant. Don't know when it will be released but have seen some spy pixs of it. They will have to up the HP on the vette cause the Northstar makes more power than the LS1. Also heard that they will have a special edition Z06 Dale Earnhart model in 04.
  3. #3
    Registered chrker's Avatar
    Join Date
    Oct 2001
    I donít know anything about it that isnít considered rumor at this point. Here is a list of what I can find. Some of it backs up what gmhdfan said about the Northstar engine.
    2004 Chevrolet Corvette C6
    - The C6 Corvette is still scheduled to arrive in 2004 (possibly available in winter 2003) and may sport a 6.0 liter 450hp V8. The 6L engine is rumored to have 2 cam shafts (one for incoming and outgoing air) and a output and cylinder deactivation system for improved fuel efficiency similar to that found in Mercedes-Benz V8s and V12s.
    - The C6 design is being led by Tom Peters, the man responsible for Pontiac's controversial Aztek. We're told that Peters' team is looking at ways to downsize the current C5 Corvette, which they see as larger than ideal, but without sacrificing interior or trunk capacity. One competitor the team has benchmarked is Porsche's Boxster.
    - Other possibilities for the C6 include a relocated transaxle (behind the rear axle) with sequential-shift manual/automatic and switching to a 4.0L Northstar DOHC V-8 (though the OHV LS1 is being breathed on to produce an honest 400 hp for 2003).
    - The C6 Corvette could include a shift away from Sheet Molded Composite (SMC), or fiberglass for the body structure and be replaced by aluminum. However, there is also a possibility that the C6 will continue to be built on the C5 hydro formed structure due to its excellent construction and stiffness.
    - GM may not replace the OHV engine with a DOHC type because of cost, packaging, previous investments into the LS1/LS6 design, and fuel economy. The last point would seem unlikely when you compare the fuel economy of the ZR-1's LT5 engine to that of the C4 generation's LT1 engine.
    - 3rd or 4t generation Active Handling System.
    - Larger brakes new wider wheels.
    - Xenon headlamps.
    - Electronic adjustable suspension.
    - Voice activated navigation system and assistance from Cadillac On-Star.
    - Analog gauges with a small digital display for other statistics.
    2004 Corvette C6 (available as early as the winter of 2003 as a 2004 model)
    Price: $42-50,000 + (Can $65-78,000) Est.
    Status: Concept
  4. #4
    Join Date
    Oct 2001
    2004 Corvette C6 Vehicle Specifications (Proposed)
    Powertrain Layout: Front engine (hp/L)
    Engine Type: 16 valve/dual OHV SFI 90į V-8
    Displacement: 5.7L or 6.0L, 366.1 cu in.
    Horsepower: 375-430 Bhp @6000 Rpm
    Torque: 390-425 lb-ft @4500 Rpm
    Max engine speed or Redline: 6600 Rpm (fuel shutoff)
    Fuel EPA City/Highway: 19/32mpg
    Wheelbase: 104.5 in
    Height: 47.7 in
    Width: 73.6 in
    Length: 179.1 in
    Weight: 3000-3150 kg
    Weight Distribution f/r 104.5 in: 50 %/50 %
    0-60 mph (Acceleration): 4.0-4.5 sec
    0-100 mph: 10-11.0 sec
    0-150 mph: 26.0-28.0 sec
    1/4 mile: 12.5-13.0 sec @110-114 mph
    1 mile: 30-31.0 sec @ 158-161 mph
    Top speed (172 Hardtop, 168 convertible): 175-180 mph,(281.4-290 km/h)
    Brakes & Tires
    Tires f/r (Good-Year Eagle F1 Super Car): 255-265-17f, 275-305-18r
    Brakes: Vented slotted discs ABS (12.5-13" f & r)
    Braking distance from 60-0 mph: 99-110ft
    Drivetrain & Gears
    Transmission (M12): 6-speed Manual or 5-speed Automatic
    1st Gear: --
    2nd: --
    3rd: --
    4th: --
    5th: --
    6th: --
    Reverse: --
    Final Drive ratio: --
    Lateral Acceleration in G force: 0.95-1.05+g
    Drag ratio ( Cd ): 0.27-0.29
    Down force ( Cz ): n/a
  5. #5
    Join Date
    Oct 2001
    I donít know if these images represent the actual car or not but it is all I can find.
    Concept drawing #1:
    Attached Images Attached Images
  6. #6
    Join Date
    Oct 2001
    Concept drawing #2:
  7. #7
    Join Date
    Oct 2001
    Concept drawing #3:
Similar Threads
  1. Replies: 16
    Last Post: 09-16-2007, 05:19 PM
  2. 2004 Ford F250 PSD Or 2004 Dodge Ram 2500 CTD
    By 289FIA in forum Trucks, Trailers and Transportation
    Last Post: 11-15-2005, 09:16 PM
  3. C6 is not a Corvette
    By HyperBaja in forum General Boating Discussion
    Last Post: 12-18-2003, 10:10 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
