Mercruiser killer ??????
Oh...... the times are a changing!!!!! now if they make an transom plate to adapt from a TRS to their unit..... we already have the tranny.......intresting.........
I too saw this in this months
Popular Science Magazine.
Looks like the prop selection is
more user friendly.
The steering system looks
a little "cheezy", maybe not
up to task for hi perf. setups.
my .02
jt
more user friendly.
my .02
jt
Registered User
1 Post
Help me understand. This is a direct drive?? SO how could it be used in a v hull?? Do you mount the motor at an angle and have a UV joint? Can you mount a motor low enough to hook up to it?
I like the idea, just not sure how it hooks up?
Interesting concept. You will need a down angle, offset tranny which has full power reverse capabilities and gear reduction though.
It looked to be different from the arneson or pulse in that it doesn't use a single shaft. The prop shaft looks to be angled upward, parallel to the bottom of the boat. I would think that this feature would allow better trim control and a shorter drive.
Gary
Gary
