when tackling a big project.............
which is the best order to start ......engines,drives glasswork paintwork, interior rigging or what? any answer greatly appreciated to give some forward motion
Sling
When I did my 41 a couple of years ago, I started with the paint because it was the biggest ugly part and the engines ran fine. Well, then I hurt an engine and decided to pull them out and freshen them up. Well, while the engines are out I decided to do the gauges and dash. Well, while the dash is out why not do the cockpit. So, as you can see, I didn't really have a plan, it just kind of worked out that way.
I guess if I had to schedule the work, I would get all the hardware out/off the boat that needed to come out/off. Do any glass work and paint prep, and before painting do any rigging that needed to be done. While all that is going on have the cockpit at the upolstery shop getting done and the engines/drives being looked at. Then get the boat to the paint shop for painting and then after painting all the other stuff should be ready to go into the boat .
Sounds easy huh? Good luck with your boat and I hope that it turns out great.
Robert
Robert
MY SCHEDULE IS GOING AS FOLLOWS
1. STRIP(ITS GOING TO BARE FIBERGLASS)
2.GLASSWORK
3. PAINTWORK
4.INTERIOR CHECK FIT(MAKE ANY CHANGES-RE COVER)
5. REBUILD ENGINES AND DRIVES
6. RE ASSEMBLE ENTIRE PACKAGE
EVERYTHING IS EITHER BEING RE CONDITIONED OR REPLACED...........
2.GLASSWORK
3. PAINTWORK
Sling
Are taking all the wiring out also? Are you staying with the trips? Should be a great boat when your done, just don't get in a hurry or things will go wrong, that's what happens to me anyway.
Robert
Robert
Originally posted by Tonto
Sling
Robert
Sling
Robert
speel chekk this fokker!
will there be any shipping of parts over thecourse of this project?
i'm in florida till the 24 but it would be good if my parts arrived (coated or not) shortly after i return.
when your boat is done it will be trick.
Pardon me, while I whip this out!
