View Poll Results: Synthetic oil or not?
Yes I use synthetic oil
301
65.72%
No I do not use synthetic oil
140
30.57%
Hell, I don't even know where the oil cap is
17
3.71%
Voters: 458. You may not vote on this poll
Poll: Synthetic engine oil or no?
#131
Re: Poll: Synthetic engine oil or no?
Originally Posted by wiggler4490
Swepco is less than 6$ quart. I'll have my rep post the exact specs on the oil. The ingredients are labeled on the product. They use the absolute best ingredients available. Not asking everyone to believe me, just check it out for yourself. There are OEM's using it exclusively. It works , Several of us high performance LOTO boaters have changed and love it, picked up 2 mph with Swepco oils. call them and they'll tell you what you want to know.
The base is close to equal to a PAO...it's a refined conventional oil....need to know detergents...antiwear additives..friction modifiers...viscosity improvers...TBN...HTTP...cSTs@100*C...
...NOAK Volatility....if esters are added...anti-corrosion additives and Flash Points and fire points.
I DO have all that information on:
Mobil-1 products
Amsoil products
Redline Products
Penzoil Products
Kendall Products
Exxon products
Castrol Prodcts
A few Royal Purple products they are a Grade 2 carrier 20% and then 80% PAO...a bit unusual but good as they have lots of ZDDP...moly too.
No data....no gonna try ...
#132
A to Z
Originally Posted by Hydrocruiser
How about posting the ingredients...
The base is colse to equal to a PAO...it's a refined conventional oil....need to know detergents...antiwear additives..friction modifiers...viscosity improvers...TBN...HTTP...cSTs@100*C...
Mobil-1 products
Amsoil products
Redline Products
Penzoil Products
Kendall Products
Exxon products
Castrol Prodcts
Mobil-1 products
Amsoil products
Redline Products
Penzoil Products
Kendall Products
Exxon products
Castrol Prodcts
#133
Originally Posted by Sean H
it feels slick.... and its a pretty purple kinda color..
Slick is from whatever friction modifier is in it...most use moly...
The purple in Royal Purple is just a dye I was told. This may be too.
Marketing 101...looks pretty
Why aren't the oil guys on bob's site interested in looking into this product? They taked about it a bit then stopped. I am not sure paraffinic based oils interest them all that much. I don't know a whole lot about these bases...they are decent....I do want to know the additives in it....and the chemical heat and shear properties before saying anything more.
#134
A to Z
#135
i know some of the guys running this stuff and they seem to swear by it and it seems to work okay in big HP motors...
Nothing goes in "my pan" until I see the specs.
Swepco "features"...
Contains DIMONYL.....what is that?
Contains organic Moly which plates all vital metal surfaces...how much..too much can flat-top?? with a friction reducing film.
Highly effective anti-oxidant additive.....which ones??
Increases chemical and thermal stability of any oil...in what way?
Need to know:
VI
HTTP
TBN
NOAK Volatility
Base stock grade
Additives
Flash Point
Fire Point
With oil either you have the specs and know or it's an advertising game. This could be great stuff...let's get the information.
So far we know it's slick..Purple..OEMs have been given some probably..and a few stories..
#136
I'll call the National Sales Rep in the mourning and have him post all the info you requested and his number. He is very sharp and can explain all the features and every partical in the formula. He loves and believes in the product. Nortech for one has done extensive testing with thiis oil and dynoed with and without it, tested viscosity after use, checked friction and have saw horsepower gains, I dont see alot of 1150+hp motors running 200 hours before even checking them. I believe the oil and maintenance sc hedule is huge on the longevity of the motor. We are the dealer at loto for it. I'll send you a free case, if it does'nt outperform your current oil and your oil analysis at 20 hours is'nt awesome , Its your for free. That was the deal I was made, Swepco is 100% confident in their product and after using it I know why. Just looked at the oil after 20 hours with 2 well respected mechanics and they could'nt believe how well its held up.
#139
Hopefully we will get some users to run hard on big blower motors and see what things like like on teardown.
#140
I got a million e-mails about SWEPCO and what a "paraffinic" base is.
An oil can be synthesized in one of two fashions... totally made from scratch using ester base stocks as Jet A/V oil is made..or...from conventional oil and then synthesized or changed using chemical processes. Parafinnic bases are SIMILIAR to a PAO product but not to an ester product. They generally are thus comparable to much of what the base-stocks of Amsoil; Royal Purple; Mobil-1 and Penzoil Platinum etc. offer in the way of basestock performance. Which is fine.
The question is what additives are in it?
Sounds like a lot of moly as it is a "slick oil" as some have suggested. That would be similar then to Royal Purple which has lots of moly and ZDDP as well. RP has been shown to reduce drag and increase HP by reducing friction. A lot of moly makes an oil act "weird" I am told if and when mixed with gasoline from blow-by. POA's mix with gas well and so do products with heavier ester bases such as Redline.
I personally like a balanced oil....heavy on the ZDDP...a solid base that can handle 450-500*F...good detergents like boron and calcium...a moderate dose of moly if any is fine...and good dispersant's as well.
I think redline as many of Bob's foks do as well has a very heavy detergent additive package which includes silicon and aluminum...along with a lot of moly... Some say RP has too much moly...it seems after much work that Amsoil Series 2000 and 3000 products and many of the Mobil products have the balance I am looking for.
I hear the guys at Sterling looked at how oils mix with gas in blown engines...I heard today they are still using Mobil-1.
Pick what you like..just be informed is my motto.
