I Have a PPI PC2350 if anyone is interested. 517-202-6611
http://www.hallcrash.com/partroy/ppiimages/pc2350.gif Power Output: 4 ohms 350W x 2 Power Output: 2 ohms 700W x 2 Power Output: 4 ohms Bridged Mono 1400W x 1 THD: 0.02 % Signal/Noise Ratio: 105 dB Frequency Response: 4.5 Hz - 100 kHz Sensitivity: 0.15 V - 12 V Damping: > 500 Dimensions: 8.9" x 25.25" x 2.25" QBass: Yes - QBass Plus Crossover Slope: 24 dB/Octave Crossover Frequency: 90 Hz Crossover Type: 2 Way Internal Fan: Yes OG :cool: |
Jon,
Thanks for the reply. And don't worry about it. If I liked it or not it was stolen so I have to replace it anyway. As for price I want to stay under $400. From what I've seen (correct me if I'm wrong) It would be hard to get a good 5 ch amp for under that? ????? Do you recommend any other amps that would compare to Rockford in quality and performance for a 4ch amp?????? Soundstream Picasso series(found a Pic4.880 for $269) JL JBL Would these be good Rockford 4 ch amps? Found them on ebay for under $250 500x 4ch will put out 62.5 watts at 4 ohms 550x 4ch will put out 68.75 watts at 4 ohms 700x 4ch will put out 87.5 watts at 4ohms How much difference will there be between 62 watts and 87 watts? Would I really be able to tell the difference beteween the to? Quality wise between the punch and the power series amps what is the difference?????? The amp to power my 2 10" subs (cant afford the 1000bd) So wouldn't these be enough to power the Access Tech subs with good quality. 250M 1ch amp 250 watts at 2 ohms 301M 1ch amp 300 watts at 2 ohms 351M 1ch amp 350 watts at 2 ohms 500X 4ch amp 250 watts at 4 ohms bridged Is there any other 1 ch amps that you would suggest???? Now remember I am going from a small 5 ch amp the was putting out 25 watts x 4 at 4 ohms 150 watts x 1 at 2 ohms I'm lost on all this crap. Since I'm not in the business it's hard to tell what is a good deal or not. |
I know you talked about a budget of $400.00 but just be carful not to under power your speakers. Remember you get what you pay for and good amps are not cheap. Stick with 4ohms and 2 amps. I have always been told that it is better to go a little over your rated watts for your speakers than to under power them. And dont forget to put a good cap on the system.
Save up some more money and go with the 750s and 750x you wont be disapointed.
:D |
I was thinking of eather going with 2 4 ch amps. 2 550x's or 1 700x and 1 500x.
Does any one know the diff between the punch and power series? for the speakers 550x 4ch will put out 68.75 watts at 4 ohms $205 700x 4ch will put out 87.5 watts at 4ohms $241 750x 4ch will put out 93.75 watts at 4 ohms $290 for the subs 750s 2ch will put out 187 watts at 4ohms $275 550x 4ch will put out 275 x 2 at 4 ohms bridged. $205 500x 4ch will put out 250 x 2 at 4 ohms bridged. $180 so if I go with the 2 550's $410 if i go with the 700x and 500 $420 if i go with the 750x and 750s $565 These prices are all on ebay I was just comparing. Russ |
From what I am told the power series is the newer and better quailty amp.
Also check the site I mentioned in an earlier post. 750x $329.95 750s $329.95 |
If you are going with a small box encloser them I would go with this.
http://www.crutchfield.com/cgi-bin/S...0&I=107MM104++ If you are going to have them in more open space then these. http://www.crutchfield.com/cgi-bin/S...0&I=107GNX10++ |
I've got all the speakers and subs. Just need the amps or amp to power it.
Russ |
Sorry about that Russ, I forgot you already had the subs. Who makes your 10" Access Subs?
I would use a 750 x on the mids and definatly the power1000bd on the subs
