New 36' Spectre cat w Arneson ASD 6
#81
Re: New 36' Spectre cat w Arneson ASD 6
Rik, up to what HP/TQ can a ASD8 handle vs a #6, both with the same Bam DrySump Cyborg 1550 trannies. Thanks Jeff
#82
arneson-industries.com
Offshoreonly Advertiser
I'm not sure of what Mercury's ratings are and that information would best come from them.
The ASD8-6 Drive Units are rated for applications up to 1,500 hp. These are the same ones that David Scott has on the 46' Skater "Barcadi" that runs in SBI. I do not know the HP of those engines though.
#84
#85
Originally Posted by Rik
Rob, they all fit the same place regardless of boat or hull type. I mount them at a certain point, in Mercury Language one might call it an "X" dimension, and that is it.
Its simple geometry. Based upon the transom angle, the height will need to be in this certain point of installed height give or take an allowable amount. Being off a small bit will not really make any difference.
below the center line of the crank shaft..it seems to me that the Arnison just pushes the hull forward . Would this be the reason for the faster speed with them??
Rik am I thinking this correctly?
Rob
#86
In essence yes. The lower drag and less parasitic loss of hp in the drive line makes a difference as well.
#87
Here is a informative article on surface propulsion theory.
Kind of long winded but sounds good http://www.simplicity-marine.com/surfprop.htm
#88
Forget the drives, Why did you get a Spectre instead of a Motion?? Just Kidding!! Before I went with the #6's, I was seriously considering ASD-6 Arnesons to replace my Bravos, Then we decided to go with big power and realised the ASD-6 would probably be too small. I would love to know how the Arnesons work out for you. Good luck
#89
Yep, that's Tony's boat. He beats that thing to death and has no problems with the drives. That's got to be one of the only boats on the Delta that never loses a drive. I know he's real happy with the way it turned out and performs. I think he tops out at 105? Not bad for a big heavy pig!
#90
Thanks caveman, great article, very in depth, but I learned alot Jeff
