If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Were doomed! Charter Member Wally's Avatar
    My Boats:
    Chris Craft Stinger 222
    Join Date
    Oct 2000
    Chicago, IL
    Try and reset all the codes and see if it repeats dually had a LEAN MIX BANK 2 once on the way down to fl going through alligator alley......truck stumbled for a sec and caught itself.....engine light came on and stayed on the rest of the trip......went to the first dealer i could find and they just rest it and said come back if it happens again! Said that i may have gotten a goofy batch of gas or something....well it never happened again after that so i have no idea what it was all about.
    As long as the engine light doesnt start to flash its more then likely a sensor problem and not super critical
  2. #12
    Charter Member Charter Member Ted G's Avatar
    My Boats:
    Marlago 35 FS, 18 Neptune CC
    Join Date
    Jan 2001
    Edgerock Baby!!
    2 things:
    You may need to clean the throttle body-there is likely a ring of varnish near the plate that is causing it to stick.
    You may also have a sticking EGR-give it a little more time and it will get worse and be much easier to diagnose.
  3. #13
    My Boats:
    1984 Chris Cat
    Join Date
    Jul 2002
    Troy, Mich
    Just Once:
    Clear the codes and run some Chevron Techron fuel injector cleaner through. Also a trick is to unhook the ground cable from the battery for about 30 minutes. The "brain" then defaults to it's regular programming, but only do this if clearing the codes doesn't work. My 97 Tahoe gave me a check engine light, said an O2 sensor was bad. We put platinum plugs in it and reset the codes, runs like a champ. If you have good plugs and wires it should run fine.
Similar Threads
  1. '89 7.4L with prob. wiped cam- what grind to use?
    By zimm17 in forum General Q & A
    Last Post: 06-15-2007, 06:44 AM
  2. Weird cooling prob
    By 97BossHammer in forum General Q & A
    Last Post: 05-09-2004, 11:16 PM
  3. Sorry not rewerse prob forward
    By mattis75 in forum General Q & A
    Last Post: 08-17-2003, 07:08 PM
  4. 96 tahoe prob.
    By JUSTONCE in forum General Boating Discussion
    Last Post: 04-29-2003, 05:33 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
